koni/Bilstein.shocks
Old Jul 6, 2008 | 01:37 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Would you guys buy the "Bilstein" or the "Koni" ? Sorry, I just can't decide? and who has these the cheapest
Old Jul 6, 2008 | 01:49 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Re: koni/Bilstein.shocks
I have read all there is on this site about them.. But, I wish someone could give me some 1st hand exp. with these..I will be using them for a little road racing, a little track, and mostly street driving..I have had the koni on my SVO but once i adjusted them a few time's. I never needed to adjust them again. The Ford lighting comes with the Bilstein as does the Syclone. I was told that they offer the same handling as the koni BUT with a better ride more comfortable. What do you think?
Old Jul 6, 2008 | 01:56 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
I used the Bilstein when I did my front end rebuild. All things considered, they are much better than stock. Konis, however are adjustable. Cost is also a factor. Just have to do a search on the net, find the cheapest price.
http://www.allshocks.com/bilstein/html/show_shocks.asp?make='CHEVROLET'&model='Camaro%20All%20Models'&year='1987'
http://eshocks.com/bil_veh.asp?Model...tein&SubChar=Q
http://www.shockwarehouse.com/index....cted_year=1987
http://www.shox.com/appguide/shoxsho...ctsdisplay.php
http://www.eshocks.com/bil_veh.asp?M...Koni&SubChar=Q
Old Jul 6, 2008 | 02:12 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Transmission: Jerico
Axle/Gears: Aluminum 8.6 w/ T2R
Koni and Bilstein both make good shocks. I have yellow koni's on my camaro and I put Bilstein HD's on my dads truck. Obviously totally different applications. I wish I had put the Bilsteins on my truck instead of the junk Monroe's
What you pick depends slightly one your intended spring rates. I've heard that the rear Bilsteins off the shelf might not be best if you are running higher rate rear springs.
I haven't heard much about the front struts for a 3rd gen.
But since you say that you plan on doing many different things with your car I would recommend the Yellow Koni Sports. You can turn down the damping for a smooth ride on the street, and crank them up for the track.
Old Jul 6, 2008 | 05:39 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Thanks for the input.. i guess i will try the yellow koni..
Old Jul 6, 2008 | 06:52 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Hotpart.com has the best price on Koni Yellows that I have seen. Plus, I think they offer free shipping.
Old Jul 7, 2008 | 09:17 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Great I will try there also
Old Jul 7, 2008 | 12:36 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
hotparts are the chepest so far at 233.91/108.52 total: 684.86
Old Jul 7, 2008 | 08:22 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Summit is a little cheaper. 639.00 for the set of koni
Old Jul 7, 2008 | 09:56 PM
hotpart's Avatar
Your not comparing the same struts and shocks. The Koni yellow sports from Summit are $725.80 not $639.00. It looks like you are looking at the Koni classic from Summit.
Old Jul 7, 2008 | 10:07 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I have Koni yellow's on a DD, not a single complaint.
EDIT: They do not ride to harsh. I do have the rears on the softest setting, fronts 1 turn from full soft. Now if you crank the fronts and rears, yes it is too harsh for roads. But that's why I bought them, so I can adjust them.
Old Jul 8, 2008 | 08:43 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
same part numbers..check e-bay thats where i found summits price's.. Then i callled summit, and gave them the part number i got off of the hotparts site? Thanks for looking out 4 me :-)
Old Jul 8, 2008 | 08:52 AM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
i did some more looking into the difference between the two, and it looks like the bilstein ride better on a day to day car, and the koni are a harsher ride, So on a bumpy road or street road the Bilstein should ride better,and handle better because they rebound quicker making the car a more stable over the road, The koni should perform better on a smoth road as there damping ability is slower, but they can be ajusted for the track/road your driving..they also put bilstein on the police tahoe..but im not sure what cars come with them?
Old Jul 8, 2008 | 01:26 PM
BIG_MODS's Avatar
Car: 87 IROC
Engine: 5.3L
Are you talking about bilstein vs Koni in general? or specifically for a 3rd gen? I'm sure Bilstein or Koni can talor a shock to requirements of the customer (OE customer), be it a SUV or car or whatever. So don't draw conclusions based on other applications.
I will say that when I have my Koni's on full soft the car rides better than it did with the old Gabriels fronts and original 130k mile rears.
Old Jul 23, 2008 | 07:31 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Transmission: TH350C
Axle/Gears: 3:23
Koni Yellows should do it for light track use. That's what I use them for on my TA and I have no complaints.
Old Jul 23, 2008 | 08:34 PM
gen 1's Avatar
Car: 1992 b4c 1le
Engine: 5.7
Transmission: auto
Axle/Gears: 3:23
Well, Thank's for all the input from everybody..I am going with Bilstein..HD Now to find the very best price....any thought's and thanks to all for the feed back..as i will up date you with the result's
Old Jul 23, 2008 | 10:07 PM
George's Avatar
Car: 83WS6TA
Engine: ZZ4
Axle/Gears: 3:23
Bilstein is probably the better choice for a car that will see more street time than track time - which means most cars so you've likely picked the best ones for your application.
The only reason my car gets driven on the road is because I have nowhere to store a trailer for hauling it to the track..lol
