Front Sway Bar Bracket
Old Jul 8, 2008 | 07:42 AM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
I took my Front Sway Bar Bracket driver side w/ 3 screws off to paint it and notice that a piece was just separated. Is this bracket broken or is this piece suppose to be this way.
Here is a picture.
Old Jul 8, 2008 | 09:07 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front Sway Bar Bracket
Interesting. I don't believe I've ever seen that piece.
JamesC
Old Jul 8, 2008 | 12:27 PM
sleepsinshed's Avatar
Car: 1988 IROC
Axle/Gears: 3:27 9-bolt
Me neither. Is this from an aftermarket setup?
Old Jul 8, 2008 | 01:02 PM
DTL504's Avatar
This is the bracket thats under the steering gear box connected to the frame by three bolts. This bracket has two holes which the driver side sway bar is mounted.
Old Jul 8, 2008 | 01:32 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Do you know where that piece was (the peice you think broke off) in relationship to the rest of it? I remember seeing that piece when I changed my front sway bar a couple weeks ago. I'll have to go take a look at it now.
Old Jul 8, 2008 | 01:57 PM
DTL504's Avatar
It's located under the sreetring gear box, If you look under your car you should be able to see if that small piece is connected to the bracket. If not it will be separated on the back of the gear box. The bolt that holds the small piece together is behind the gear box.
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
ProtoMaster22
Aug 26, 2015 07:50 AM
