How do I install endlinks?
Old Jul 9, 2008 | 08:55 AM
ohiotemplar's Avatar
Car: 1992 Camaro RS V6
Engine: 3.1 V6 MFI
Axle/Gears: 3.23 stock
I just got the poly zinc coated endlinks off spohn. Can I drive the car up on ramps and change them, or should I jack it up and pull of the tires?
How tightly should I crank down on the bushings?
Old Jul 9, 2008 | 09:57 AM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
Re: How do I install endlinks?
Are you talking about the rear sway bar end links?
I slid under my car in the garage with no jack or anything. But it was TIGHT and I almost pulled some joints out of socket .
If I had it to do over again, the easiest way would be to get it on a grease pit or a lift that lifts the car by the tires and work from under the car. The ramps should work, too. Or you can jack it up and remove your wheels to get to them easier. But jacking and removing wheels is a pain to me. I'm always afraid I'm going to knock a fender out of alignment with the jack. I've heard too many horror stories about that.
Old Jul 9, 2008 | 10:21 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
I installed some this past weekend. I backed my car up on ramps. Then worked off the floor. Be sure to put some Kroil or PBlaster on the old end-link threads. I just tightened them to where they felt right, but Ive heard some people say to torque them to 18ft lbs
Old Jul 9, 2008 | 10:38 AM
Engine: 3.1 V6 MFI
No I mean the front end links. So basically I don't HAVE to take the tires off? That's great! Thanks!
Old Jul 9, 2008 | 11:24 AM
mesterz2889's Avatar
you dont have to take off the wheels but it would be a lot easier
Old Jul 9, 2008 | 02:05 PM
Engine: 3.1 V6 MFI
Got 'er done just by cutting the wheels right and left. Wasn't hard at all. You just have to go in through the front.
Old Jul 9, 2008 | 02:59 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Apr 25, 2017 07:14 AM
dennisbernal91z
Fabrication
29
Mar 2, 2017 12:04 PM
gixxer92
Sep 1, 2015 04:32 PM
86IROC112
Aug 17, 2015 07:57 PM
