South Side Machine Trailing Arms& Crossover
Old Jul 14, 2008 | 05:51 PM
kyleiroc88's Avatar
Car: 88 iroc-z, 86 trans am
Engine: lt1
Transmission: 700r4 tci streetfighter
Axle/Gears: '02 10 bolt, slp auburn diff
anybody ever seen these before or heard anything about them? are they suppose to be better than a panhard bar?
http://cgi.ebay.com/ebaymotors/T-A-C...QQcmdZViewItem
Old Jul 14, 2008 | 06:06 PM
stroked_n_blown's Avatar
Car: '92 Camaro RS
Engine: 305 TBI
Transmission: Richmond Gear street 5 speed
Re: South Side Machine Trailing Arms& Crossover
SSM's product was very popular when it was being made. The guy selling it is a bit off on hi description. If I remember correctly, it doesn't replace the panhard rod at all. What it does do is replace the LCA's and adds a crossmember in the center of the car to attach them to. YOu can getthe idea by looking at the pics he has of how it sets up. THe control arms get welded onto the axle tubes, and then attach to the crossmember. One benefit of it is it also allows you to run fat tires if you tub your car at all because the LCA's will be farther inboard.
Old Jul 14, 2008 | 07:01 PM
ross's Avatar
Car: 82 camaro
Engine: 434 ci
Transmission: t400
Axle/Gears: 9'' 4.10 gear
I have that kit on my car and when I bought them I was told to leave the lower controll arms in. The kit also came with sub frame con. that the cross bar tied into. I have been 1.40 60ft with drag radials but I will tell you i am trying to get the parts to put the torq arm back in the car.
Old Jul 14, 2008 | 07:17 PM
Stephen's Avatar
Car: 87 GTA
Welded on to the rear end housing....Wouldn't change your pinion angle, all though the suspension travel?
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Sep 29, 2015 01:50 PM
utfan01ss
Sep 28, 2015 12:17 PM
gixxer92
Sep 1, 2015 04:32 PM
anesthes
Aug 24, 2015 08:18 PM
