Offset on 02 camaro SS wheels
Old Jul 24, 2008 | 08:56 AM
camarobird92's Avatar
Car: 95 Z28, 92 Camarobird
Engine: 410 rearwheel hp LT1, TBI 305
Transmission: 4L60E, 700R4
Axle/Gears: 4.11's, Whatever BS GM put in it
Does anybody know if the 02 SS wheels are offset different on the front and rear? I put a set of them on my 95 Z28 and now my right rear tire is flush with the outside of the quarter and my left rear is sunk in about an inch. Is it possible that I put a front wheel on the rear? Are those wheels the same for front and rear?
Old Jul 24, 2008 | 08:06 PM
Tru2Chevy's Avatar
Car: 1987 Camaro
Engine: 400 sbc
Re: Offset on 02 camaro SS wheels
Yes they are the same all around. Sounds like your rear is out of alignment.
Is your car lowered at all? If so, do you have an adjustable panhard bar?
- Justin
Old Jul 25, 2008 | 12:25 AM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
There's a good answer to how much you axle gets pushed out of line when you lower it. Thank you.
Old Jul 25, 2008 | 08:25 AM
It's not lowered at all. And all the suspension is stock. Guess I just never noticed it with the stock wheels. I'm planning on hacking the flowmaster off to put a Dynomax bullet dumped before the rearend. I'll check if anything is bent then. Thanks guys.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
BlueIroc-Z
Jun 9, 2019 03:22 AM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
Fronzizzle
Aug 9, 2015 01:15 PM
