dust cover problem
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
dust cover problem
I just bought new rims and the center cap wont fit over the caps on the rotor.Does anyone make a shorter dust cap?Any help is appreciated.
thanks Mike
thanks Mike
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: dust cover problem
You'll need a bigger (longer) center cap!
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
Here is what you do.....
Take the dust cover & put a nickle or similar sized washer inside of it & install on the car. Then carefully tap it flat in the center with a hammer. Once it touches the spindle, remove the cover, take out the washer & reinstall the cover. This will give you approx .100" clearance inside from the spindle.
Hopefully this is enough to clear.
I had the same problem with wheels as you are having.....
Car: 92rs
Transmission: 350
these are bolt on caps and i dont think bigger caps will look right .
Lonnie I will try your idea , sounds like it may work.
Does anyone make a shorter dust cap?Doesnt seem like it has to be so big.
thanks again Mike
thanks again Mike
Street Lethal
Apr 30, 2019 12:14 PM
I'llrocya
Feb 2, 2016 11:43 PM
