Violent front end shake.
Old Aug 1, 2008 | 04:31 AM
panzer's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Axle/Gears: limited slip
The front shocks on my RS are really weak and Ill be replacing them soon, but whenever I hit a huge hole or bump at high speed the whole front end feels like its gonna fall off and shakes violently. I stop then it goes like nothing happened at all. Im hoping its the shocks causing that,and not ball joints,wheel bearings,tie rods,etc. The coil springs are fine though.
Old Aug 1, 2008 | 07:42 AM
raptor80dad's Avatar
Car: 92rs
Transmission: 350
Axle/Gears: 3.73/Moser 12bolt
Re: Violent front end shake.
With the right tools(ball joint remover,small tie rod puller)you can rebuild the whole steering system.Did mine in a day by myself.Parts are not expensive and it feels good knowing everything is new.You will have to have the front end aligned afterwards.
I would take it to an alignment shop and have them go over it,get a list of the problem(s) along with there price to fix it .
Then get the parts , fix it yourself and enjoy your car and all the $ you saved doing it yourself.Not hard to do if you have basic tool knowledge.
Most places do free estimates,then you can use them to do the alignment.
good luck
Old Aug 22, 2008 | 12:59 AM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
Transmission: 700-R4
mine did this, replaced the centerlink,tie rod in/out, energy bushings, balljoints, end links, sway bar, and a arm bushings. No scary shake any more !
Old Aug 22, 2008 | 05:30 AM
too-fast-85's Avatar
Car: 84 S/C
Engine: 84 305 H.O.
Transmission: 700 R4
Axle/Gears: 3:08
Mine did the same thing. The problem in my case was a worn out centerlink but I replaced the the the tie-rods and the centerlink. JUST TO BE SAFE. Hope this helps you or anyone else with this issue.
Old Aug 22, 2008 | 08:09 AM
lonesomecrow's Avatar
Car: 92 RS
Engine: 305 TBI
Axle/Gears: ??
Mine does this as well, but I need struts, shocks, springs and bushings all around, I already replaced the whole steering, wheel bearings, and still have the problem, but I think it lies in between bushings and struts.
Old Aug 22, 2008 | 05:07 PM
rough's Avatar
Car: 88 Camaro
Engine: 305 TBI
I had purchased rotors from autozone and the duralast gold series pads, now when i push on the breaks it feels like my wheels are whobbeling, wonder if it could be the rotors, hopefully this bushing project goes well this weekend.
customblackbird
Aug 15, 2021 10:16 PM
Terrell351
Jun 13, 2021 01:13 PM
Amillionoh7
May 24, 2020 08:01 AM
sweet_87_iroc
Sep 25, 2015 10:01 PM
bellez77
Sep 5, 2015 08:39 PM
