Difference in K members?
Old Aug 12, 2008 | 02:51 PM
wvabreeze's Avatar
Car: 1988 convertible Z28 I think
Engine: 30 over 350 carbed and HEI
Transmission: T5 5speed
Axle/Gears: 9bolt 327posi disk brakes
Is there a difference in the K member of a Trans Am and Camaro? After pulling the engine to clean the engine bay up I located some evidence that my car has been hammered at some time in it's life.My K member has been welded with a big gorilla weld on the back side of the A arm mounting area and a motor mount was welded on.I have found several donors but the cheapest and closest yard only has a Trans Am and doesn't look to have been wrecked.
Old Aug 12, 2008 | 03:19 PM
eeeeeefirebird's Avatar
Re: Difference in K members?
as far as i know they are the same. i have a crossmember that is sandblasted and painted black for an 89 iroc, and i dont need it, if your interested
Old Aug 12, 2008 | 09:32 PM
wvabreeze's Avatar
Thanks for the input.I have several options locally.The Trans Am would be the easiest to get.I figure I can buy one cheaper local than what shipping charges would be these days.I will most likely need to replace A-arms and all.I haven't tore mine down yet to check,it's easier to move around until I gather everything I need. I may even go tubular if some extra funds roll in sometime soon.
BAMiller
Sep 14, 2015 06:38 PM
angel2794
Sep 8, 2015 06:22 PM
greenyone
Sep 2, 2015 03:39 PM
Armored91Camaro
Aug 25, 2015 12:01 PM
Linson
Aug 21, 2015 02:12 PM
