S10 Manual Steering
Old Aug 15, 2008 | 07:49 AM
kcb37's Avatar
S10 Manual Steering
I know this has been gone over many times.
I know so far I need a gearbox out of an 84 and up 4 cyl S10, the Camaro pitman arm works best, and it will bolt right on.
My two questions are.
I have not found a part # for a serpintine belt, or a belt length, without powersteering.
I have also read that the sway bar will be in the way, and it will have to come off.
I know the wheels will be harder to turn, yes right now it is somewhat of a DD, I don't care, I bought it to race it.
It is an 89 RS, TBI 305
Old Aug 15, 2008 | 08:10 AM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: S10 Manual Steering
If you bought it to race it, take the sway bar off.
Old Aug 28, 2008 | 08:02 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
with manual steering, you gotta be one strong dude to muscle around a track through the corners.
id get rid of the sway bar.
you are going to have to get creative on the belt.
ive seen some guys put a dummy pulley where the power steering bolted up. much like the a/c delete or the smog pump delete pulley.
Old Sep 3, 2008 | 10:57 AM
kcb37's Avatar
Drag racing. Not to many turns their.
If I can find a gear box in the next week or so well find out soon enough.
Thank you for your help though.
Old Sep 3, 2008 | 12:41 PM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
Out of curiousity, what else do you have planned for the car in the near future? I'm asking because I assume there is going to be a big HP bump with a new engine to make going to manual steering worth doing. As for the sway bar, going to manual steering only seems to make sense if you're making a drag racing car that already lost the sway bar and likely is going to have skinny wheels up front.
Hotrodboba400
Dec 10, 2019 07:07 PM
Veaceonee
Sep 29, 2016 08:15 PM
Ian Irvine
Sep 4, 2015 08:08 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
