comp 3 way shock problem
Old Aug 18, 2008 | 08:24 PM
americanmuscle3's Avatar
Car: 83 z28
anyone else have comp 3 way adjustable rear shocks? i put mine in yesterday and now the rear end hangs way lower than before, and when lifted from the chassis the springs are loose has any one else had this problem? any help is appreciated thanks
Old Aug 18, 2008 | 09:36 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: comp 3 way shock problem
Did the spring rubbers fall out? Are the springs seated properly at the top?
Old Aug 18, 2008 | 10:09 PM
Car: 83 z28
rubbers are there but there is about an inch gap between the rubber and the seat on the body when the car is in the air the part # was 2700 i believe
Old Aug 18, 2008 | 10:15 PM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
Mine do the same thing. I always check the springs before I sit it back down. They usually go back in place with out touching them I was suggested to weld in some straps from the body to the rear to keep it dropping down.
Old Aug 18, 2008 | 10:42 PM
Car: 83 z28
do you have any issues while driving?
Old Aug 19, 2008 | 11:02 AM
chevymec's Avatar
Car: '92 RS
Engine: 350 carb'd
Axle/Gears: 4.10
No issues while driving. the shocks just have a longer travel than stock ones.
Old Aug 28, 2008 | 07:50 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
do you have a rear sway bar on the car?
i ran these shocks for years and no issues.
customblackbird
Aug 15, 2021 10:16 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
mz92274
Aug 25, 2015 08:47 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
