s10 box pitman arm?
s10 box pitman arm?
so i just purchased a NOS s10 manual box for my 84 t/a. and i was told the pitman arm would work, well it doesnt. its too big, is there a different 3rd gen pitman arm i could use? or another type of car? im having trouble locating a pitman arm because it is a non wear item. thanks
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: s10 box pitman arm?
Does the steering box have 4 bolts or 3 bolts on the top cover? It sounds like you have the older, smaller, 3 bolt top cover steering box. It can be modified to work however the 4 bolt top cover version is a direct swap.
You won't find a smaller sized pitman arm for that box that's the same as a third gen's pitman arm.
Car: 1985 Camaro and 1996 Mustang GT
Engine: 350 4bbl/281
Transmission: 700R4/4R70W
Axle/Gears: 9" rear/8.8" 4.10
i purchased my box for an 1987 (IIRC) S10 and retained the factory pitman arm with no issues.
Car: 87 IROC L98
The 84+ S10 boxes have a 4 bolt top cover. The pitman arms have the same diameter hole so they'll easily swap. The older boxes (3 bolt top cover) have a smaller shaft so the newer pitman arms won't fit.
bubbaz28
Sep 18, 2015 02:09 PM
Ragtop Man
Sep 12, 2015 12:23 AM
83 Crossfire TA
Sep 8, 2015 12:06 PM
