replacing strut bolts which bolts to use
Old Sep 11, 2008 | 10:39 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
i recently replaced my struts and a few suspension bushings/bolts. the stut bolts that bolt on to the spindle were trash, tried napa for replacement bolts but could not find the proper thread. anyways i used 5/8's zinc plated bolts from home depot, just wondering if there durable enough, considering this holds the spindle and strut im a bit worried if they dont hold up or break any input is apreciated thanks
Old Sep 11, 2008 | 11:05 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Re: replacing strut bolts which bolts to use
Spohn sells the bolts and nuts you need. It's a little pricey, but at least you know it will work.
http://www.spohn.net/shop/1982-1992-...dware-Kit.html
Old Sep 12, 2008 | 06:49 AM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
you need high grade/strengh bolt . home depot stuff is like grade 1-3 , you should have grade 8-10+ . think about front end falling apart at interstate speeds . put the right stuff back in . good luck .
Old Sep 12, 2008 | 08:19 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Dealer has them too.
Old Sep 12, 2008 | 08:35 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
The OEM bolts are torque-to-yield. Which would be the best for replacement. Service manual states to replace the bolts, washers, and nuts at each removal.
However, it has been known to use 5/8-11 x 3" bolts, nuts and washers in grade 8 (Lowes has them). Use red locktite and torque to 200 ft/lb.
RBob.
Old Sep 12, 2008 | 04:48 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
I wouldn't use anything less than a grade 8. Preferrably a grade 8.8 or 10.9.
Old Sep 12, 2008 | 06:18 PM
godreject's Avatar
Thanks for all the replies, bolts are 8.8 grade i just reaplced them with home depot ones because i had a hard term finding them at local auto parts and was tired of spending more time shopping for bolts then actually fixing the car, i did use locktite on the bolts, but now i can rest easy and know the bolts will hold up. i will replace them next time around, when i go and disasemble suspension parts once again and give them a scrub and paint, this will take a few weeks @ least i know i can drive the car as is thanks
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
TheExaminer
Aug 25, 2015 07:34 PM
ASE doc
Alternative Port EFI Intakes
Aug 25, 2015 09:14 AM
1992 Trans Am
Aug 9, 2015 04:32 PM
