How to set up for drag racing?
Old Sep 14, 2008 | 09:40 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
I have an adjustable tq arm (spohn, crossmember mount) SFC's, double adjustable LCA's, and lcarb's. My question is, what should I be adjusting to get it to hook better? will changing the pinion angle help at all? The car seems to squat a little harder on the passanger side, and its almost like it slides a little to the right ?
The shocks are chepo summit three way adjustables, and the springs are stock replacements (they don't sag)
Anybody have any sugestions??
Old Sep 14, 2008 | 10:37 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: How to set up for drag racing?
For total traction I'd try both settings of the lca's, mine hooks more on the lowest hole. Pinion angle is usually -2 to -4 degrees for a drag setup, and mine's at -2.5 to -3. I'm not sure what pinion angle will do as I've just set mine and drove. With the odd squatting, you could try setting the passenger side stiffer than the driver or putting air bags inside the springs with more air in the passenger side. Drag springs in the front might help traction if the front end isn't lifting quick.
Old Sep 14, 2008 | 10:51 PM
mild84's Avatar
Car: 1984 z28
Engine: 6.0
Transmission: glide
Axle/Gears: 3.50 9"
The lca's are in the lowest hole now. The front shocks are 20 years old, so they're nice and worn out . I'll have to check the pinion angle to see what its at. I have never adjusted it, just bolted it in and went. Lately my 60' have started to go away, so I figured I would start playing with the suspention. I think I will go ahead and order a drag bag for the right rear, and see if that will help.
Terrell351
Jun 13, 2021 01:13 PM
AussiePr0nCar
Mar 6, 2020 04:04 PM
Vintageracer
Jan 10, 2020 05:33 PM
Street Lethal
Apr 30, 2019 12:14 PM
Dialed_In
Aug 20, 2015 01:45 PM
