Looking for some new sfc
Old Sep 21, 2008 | 08:00 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I am looking for some new sfc. The ones right now are cut so my exhaust can fit, along with the exhaust dented in so it could fit. What I am looking for is a set that will work with my 3.5 inch exhaust along with a 2.5 y pipe and a crossmember mounted torque arm. Which ones will fit without modifying the exhaust. Which ones work great for you guys and any pics
Mitchell
Old Sep 21, 2008 | 09:18 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Looking for some new sfc
Which ones you have? I'm pretty sure Spohn or UMI would fit your needs.
Old Sep 21, 2008 | 09:40 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
I have some cheap 50 dollar ones i got at a swap meet
Old Sep 22, 2008 | 02:32 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
^I agree^
Spohn or UMI
Last edited by racing geek; Sep 22, 2008 at 02:33 PM. Reason: Automerged Doublepost
Old Sep 22, 2008 | 04:53 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
but will they fit with what i have without any mods
Old Sep 22, 2008 | 08:07 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Go to their websites and look at the pictures they have. You should be able to see if they will or not.
Old Oct 20, 2008 | 02:04 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Just an FYI UMI has a 15% off group purchase going on right now.
https://www.thirdgen.org/forums/grou...ml#post3923248
Old Oct 21, 2008 | 12:24 AM
Mikz86TA's Avatar
Car: '86 Trans Am and '03 S-10
Engine: 355ci and 4.3l
Transmission: 700R4 and NV3500
Axle/Gears: 7.625/3.42 Auburn and 8.5/3.08 Gov-
Do you have a pic of your exhaust setup. What kind is it or is it custom made?
I have Alston. They are tube and the right one goes over the cat converter area. I could meaure for you how low it hangs at that point.
Not the best pics, but all I have at the moment.
BTW, I have 3" exhaust and a 3" test pipe.
Old Oct 23, 2008 | 11:48 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Does anyone know if the Spohn or UMI SFC will work with a 3.5 mufflex single exhaust? I don't want to order one and find out it won't fit
Old Oct 23, 2008 | 01:02 PM
goomaan's Avatar
Car: 1987 IROC-Z
PM UMI Performance vbmenu_register("postmenu_3921013", true); Ryan will tell you if there are any issues
Old Oct 24, 2008 | 06:11 PM
blacksunshine'91's Avatar
Transmission: Pro-built 700R4
Look into the Global West sfc's. They look great on my car ('91 GTA). Those ones in the pics above would never work on my car since it has been lowered. The GW sfc's wrap around the tunnels(?) on the outside of the floorpans. They installed without any problems with my aftermarket exhaust which has dual cats. I believe James C has them as well. I was very pleased with the quality and fit.
Old Oct 24, 2008 | 09:31 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I like the TDS ones:
http://www.top-downsolutions.com/pro...products_id=90
Old Oct 25, 2008 | 02:35 AM
Mikz86TA's Avatar
Mines lowered. Eibach ProKit and Alston SFC's.
Old Oct 25, 2008 | 03:31 PM
Originally Posted by Xlr8torZ28
Those are made by Alston. Those do look nice on the car above, but the Global West set appear to provide more ground clearance. Either way is fine. They both seem to have good reputations on this board.
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
kairles
Oct 26, 2015 09:13 PM
luvofjah
Sep 26, 2015 08:28 PM
luvofjah
Sep 10, 2015 10:41 AM
BadSS
Aftermarket Product Review
Apr 28, 2001 05:02 AM
