Offset
Offset
Quick questions about offset. I know the fronts need to be 0 offset and the rear +16. Problem is the wheels I have found can be 0, and the best that can do is +12. How will using the +12 instead of +16 effect the car and look? Will it even fit?
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Offset
what width?
thats only a 4mm difference, they should fit with no problems, depending on size and width of course
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Re: Offset
The rear wheel offset doesn't have to be 16mm as you can use the 0mm. For example I have front single stripe IROC wheel at all 4 corners with no problems. The only visual difference is the tires sit 16mm to the outside and it sure makes rotating much easier (provided your front/back tires are the same size).
88SS6SPEED
Nov 11, 2015 07:05 AM
rb85TA
26
Sep 14, 2015 10:29 PM
