Hotpart Control Arms???
Old Sep 26, 2008 | 06:58 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
Does anyone know if these control arms are anygood? http://www.hotpart.com/index.php?p=show&id=10
They seem like they would work, but i don't wanna buy control arms that will bind up anyway.
Are J&M products any good?
Old Sep 26, 2008 | 07:42 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Re: Hotpart Control Arms???
I know a lot of guys with 4th gens run them. There are already a couple threads on theses, did you try a search yet?
Old Sep 26, 2008 | 09:08 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
yeah i've searched. Didn't find anything worth reading. So you think they work?
Old Sep 26, 2008 | 09:17 PM
krisb410's Avatar
I just searched, you fail
you already posted in a thread about these
https://www.thirdgen.org/forums/post...569-post5.html
what info are you looking for that you couldn't find in that thread?
Old Sep 26, 2008 | 09:23 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
How would that round middle acually reduce bind? It seems that the Steel bolt tube (for lack of better words) still is one piece and the outside bushings are still tight against the bolt tube and the LCA itself. To me it seems as though if you take that round bushing out nothing will change. I may be 100% wrong but thats my 2 cents.
Old Sep 26, 2008 | 09:34 PM
krisb410's Avatar
It reduces bind because the outer bushings are softer than the round bushing in the middle.
I just read that other thread, not very much info there. go to camaroz28.com and search there. Seems like a lot of guys have them.
Old Sep 26, 2008 | 09:40 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
I see, that does actually make sense. The softer bushings on the outside are allowing more twist while that round hard bushing is giveing you the ridgity you want. Looks like a pretty good design then. Thanks krisb410
Old Sep 26, 2008 | 09:51 PM
krisb410's Avatar
I have UMI adjustable LCAs. The rodends are seized, so I have Johny Joints to replace them http://www.currieenterprises.com/ces...nnyjoints.aspx. Haven't put them in yet, but hopefully soon.
Old Sep 26, 2008 | 10:14 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Those look quite impresive. Have you ever experienced "bind" in your LCAs if you ever had non rod ended ones? Reason I'm asking is because UMIs non adjustable are a good deal and ive never had bind occcur before. Does bind occur in really really hard turns or even slight turns (under 30 mph)?
Old Sep 26, 2008 | 10:27 PM
coolram62's Avatar
Car: 1983 Camaro Z/28
Engine: LU5 305 CFI
Axle/Gears: J65/G80/G92-3.23
Krisb410 those Currie ends look interesting. I'm curious as to what size (P/N I guess ) that you ordered to go on your UMI centers. I have UMI centers and have been contemplating going with the J&M LCA's because I don't want to deal will double rode ends again on the street.
Old Sep 26, 2008 | 10:33 PM
krisb410's Avatar
http://www.currieenterprises.com/ces...t.aspx?id=1262
Old Sep 26, 2008 | 10:37 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Coolram62 were the double rod ends that loud? I think im actually going to buy the J&M LCAs because of hopefully being bind free (just searched and read all about bind and i dont want that to happen) and hopefully they're quiet on the road as well. Maybe Ill wait till someone has them on thier car and gives us all a report on how they performed. $115 shipped on ebay isnt a bad deal
Old Sep 27, 2008 | 08:06 AM
planman's Avatar
Car: 92 RS
Engine: 3.1 V6
I installed the J&M Products LCA and non-adjustable panhard rod on my car 5 years ago and they are a quality product. I bought mine as a package deal on Ebay for $99.00. They virtually eliminated all wheel-hop under acceleration and extreme braking.
Old Sep 27, 2008 | 09:07 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
I have these too--very good product and service
Old Sep 27, 2008 | 10:21 AM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Ok. Thanks for the search. I didn't see that. Didn't try very hard though. I never read new posts on that last thread i posted on.
I'm gonna go ahead and get them. I'll let everyone know how they are.
Old Oct 4, 2008 | 07:32 PM
coolram62's Avatar
Engine: LU5 305 CFI
89ROC-Z they were a bit much for me for the street. Perhaps if the rod ends had been teflon lined it may have been different. Thats's why the Currie ends look interesting as do the J&M LCAs - I'm not sure which way to go yet. But I do know it won't be double rod end like I have.
Hotrodboba400
Dec 10, 2019 07:07 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
