Anyone running these on their drag car? i have them in mine. im having traction problems. I need some help on tuning them. thanks
ever since i put a spool in my car its had traction problem at the launch. i been trying to figure out how to adjust these shocks but its tough
need to figure something out
i didnt even see your post. sorry man. the car is spinning at the line. it leaves straight tho. i also have a spohn anti roll bar.
What tires does it have? Does it lift then fall or spin from the start?
QA1s are now made in China. A lot of vendors no longer carry their product because their quality is sub-par. Do not get them. I do not remember but there is a company making similar shocks that is a superior quality.
What are the current settings?
Have you got the lower control arms under control?
the shocks were set at LC 12 LR 12 RC 16 LC 12.
More info would help.
Tire size, make and model=
Spring length, lbs, preload (rear)=
Spring length,lbs, preload (front)=
Shock setting rear=
Shock setting front=
Drag bar seting neutral or preload(if so how much)=
Total weight of car=
Launch RPM (auto or standard)=
Shock setting rear=
