Have some mods, which next?
Old Oct 2, 2008 | 12:30 PM
92GTA's Avatar
I currently have a 1-piece 3-pt Kenny Brown strut tower brace, Spohn steering brace, & Spohn tubular weld-in sub-frame connectors.
An accident 3 years ago totalled my K-member and tweaked and A-arm. I plan on replacing the K-member with a Spohn tubular unit and Spohn tubular A-arms also.
My question about the k-member and a-arms are about the engine mounts and spring pockets. My LB9 is still running strong and I plan on it staying BUT if in a couple years I want to swap in an LSx, will changing the mounts be difficult and compramise the integrity of the k-member by cutting off the stock ones and welding the LSx ones on? I plan on road racing, not drag, so I'm unsure how the tubular K holds up to that.
I plan on installing Eibach Pros because I don't want to go as low as the Sportlines and I remember LPE used to sell Bilsteins for 3rd gens that were made just for lowered suspension. Are these Bilsteins still available? I don't see them on LPE's site anymore?
About the spring pockets, if I ever did want to go with coil-overs, is it now or never? Can the standard spring pockets be swapped for a coil-over setup later?
Lastly, my final mods I plan on being lowered tubular LCA's, TQ arm w/DS loops, & adjustable Panhard bar.
Well crap, lol.
I think I'll just buy this bad boy in gloss black for $1400 and use some Koni struts:
http://www.spohn.net/shop/1982-1992-...r-Package.html
Old Oct 2, 2008 | 12:45 PM
Flip 2's Avatar
Car: 1983 Firebird SE
Engine: C5 LS1
Transmission: 6 speed
Re: Have some mods, which next?
Check with Spohn on changing motor mounts.
Get LCA relocation brackets when you put in the Eibachs.
Old Oct 2, 2008 | 03:30 PM
Camaro5690's Avatar
Car: 1985 Camaro/89 Merkur XR4Ti
Engine: 5.0 305 LG4/2.3 Turbo (180hp/205tq)
Transmission: TH700R4 with Shift Improver Kit/T-9
Axle/Gears: 3.42LT1 Rear/3.64
Just a suggestion, checkout racecraft, their K members seem to be of nice quality too.
Old Oct 7, 2008 | 02:36 PM
92GTA's Avatar
I will, thanks!
Old Oct 8, 2008 | 09:27 AM
92GTA's Avatar
OUCH!
The Racecraft K-member is $649 how I want it and the same from Spohn is $835!!!
Same deal with the tubular A-arms, $399 from Racecraft but $529 from Spohn.
Thanks for pointing that out!
Alex
Old Oct 9, 2008 | 09:33 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Honestly, I would just get a set of stock pieces, weld a plate on the bottom on the bottom of the a-arms for rigidity, install Del-A-Lum bushings from Global West and use the remaining $700 on KONIs.
starliner
Feb 9, 2016 08:18 PM
Quzyle
Oct 15, 2015 03:35 PM
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
