Help with front clearances please
Old Sep 27, 2008 | 07:12 PM
UDAMON's Avatar
Car: Mazda Protege5
Here is my issue.
https://www.thirdgen.org/forums/auto...alled-aje.html
So its rubbing right now on the fender lip. I am running 2 in adapters on my wheels now. The inside edge of the wheel is in the stock location. I figured this by laying both the stock wheel and new wheel on the ground and measuring to the back of the mounting surface. The stock measured 5 and the new measured 7. So that left me with the decision of 2 in adapter.
I was considering switching to 1 1/2 adapters which would move the wheels a half in inwards.
My question is do I have enough room to shift the wheels in a half of an inch?
If not I was considering using v8 springs to raise it up some. (My car is a v6)
If I were to change springs to raise it, would it be necessary to upgrade my struts to accommodate?
Any help is appreciated, thanks!
Old Sep 28, 2008 | 05:27 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Re: Help with front clearances please
Have u rolled the fender lip yet, that will help some. Later.
Old Oct 1, 2008 | 11:37 AM
gmgod's Avatar
Car: 92 T/A VERT
Engine: LB9
Transmission: AUTO
Axle/Gears: 7.5 / 3.42's
Replace your worn out stock springs with new moog V6 springs.
Old Oct 6, 2008 | 01:25 AM
UDAMON's Avatar
Car: Mazda Protege5
i'm having trouble deciding on springs. i do want to raise it a little but not too much.
here is the choices i am torn between
1. get new v6 springs. i can assume these will raise the car some.. but will these be stiff enough to resist wheel well rubs on dips and such?
2. buy v8 lowering springs all around. this would allow me to drop the rear also. can anyone give any insight as if these would still raise the front? also would these springs be stiff enough (i assume yes)
3. or should i just buy stock v8 springs and trim (if need be) to a desired height?
so ive decided i do need to raise the front, but at the same time i want to raise it as little as possible, with the hopes that a stiffer spring will allow me to keep it as low as possible without wheel well scrapes.
Old Oct 6, 2008 | 03:01 PM
Axle/Gears: Stock
I say new Moogs for a V8 then trim to fit. Later.
Old Oct 6, 2008 | 09:55 PM
UDAMON's Avatar
Car: Mazda Protege5
ive been reading your thread Fords88Bird. so to my understanding, you decided against lowering springs because they would be too soft?
if this is the case i am liking your suggestion of cutting new v8 springs for a stiffer spring.
another thought: should i be looking into struts as well? i know it would be a good thing, i'm just wondering if i'm putting too much into the wrong area.
i was under the impression that springs set the ride height but struts control more of the suspension travel.
Old Oct 9, 2008 | 03:55 PM
UDAMON's Avatar
Car: Mazda Protege5
well i found a cheap easy fix. i just bought those coil boosters from the auto parts store. the front ones were too small so i went with the rear ones. one on each spring put me up enough i only get minor rubs on big dips.
pictures added to my original thread!
Old Oct 9, 2008 | 09:35 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Shocks would be what you needed. The ones you have aren't properly controlling the suspension. This is at least what I would think first.
gixxer92
Sep 1, 2015 04:32 PM
downsouthboy
Aug 29, 2015 11:29 AM
1Aauto
Sponsored Vendors
Aug 26, 2015 02:18 PM
kah992
Aug 19, 2015 02:55 PM
articwhiteZ
Aftermarket Vendor Review
Aug 18, 2015 07:26 AM
