Drop Spindles Installed! (AJE)
Old Sep 25, 2008 | 03:22 PM
UDAMON's Avatar
Car: Mazda Protege5
Well after 3 years and many many many phone calls and headaches.....
I have finally installed my drop spindles from AJE
Although they were not quite a direct bolt in replacement out of the box, the install went quite smoothly. The details will be left out because I do not recommend these to anyone. Although they work fine, the hassle (of trying to get all the right parts) is not worth it. But since I had them I thought I'd make them work.
I'm happy I finally have it done!!
Now should I leave it with this stance? Or should I lower the rear also?
BEFORE:
AFTER:
Old Sep 25, 2008 | 03:41 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Drop Spindles Installed! (AJE)
I think it sits wayy to low for my taste, But to each their own, i would also drop the rear it just looks plain odd when it is leaning on the front like that.
Old Sep 25, 2008 | 03:53 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Please lower the rear, IMO, it looks goofy with the back end of the car sitting up like that
Old Sep 25, 2008 | 05:56 PM
godreject's Avatar
Car: 09 GSXR/88 iroc/91 RS B4C
Engine: 600cc/l5.7/5.7
Transmission: 6 speed/TH 350/auto
Axle/Gears: 45tooth rear?/3.23/3.42
damn thats even lower then my car and i have clearense issues all the time, is this a daily driver if so have you driven it much and hows the ride, and yea lower the back a bit, and spray some armor all on those tires please lol
Old Sep 25, 2008 | 06:11 PM
CamaroBeast's Avatar
Looks good but you need to drop the back of it makes it look alot smoother
Old Sep 25, 2008 | 09:25 PM
UDAMON's Avatar
Car: Mazda Protege5
It is definitely lower then I was expecting it would be. Took it out for a ride tonight...
Need to trim the air dam. And I think my 2" spacers are a bit much now. I'll probably have them turned to 1 1/2 and hopefully that will eliminate the fender rubs without effecting the backspacing too much. And there is rub with the wheel fully turned but thats not a big deal.
Are struts necessary when dropping the rear?
Old Sep 25, 2008 | 09:42 PM
karl's-92'-z28's Avatar
Car: Too many cars
Rear are shocks.., if you drop the back the front may come up a bit maybe. Are you using stock coils in front or dropped ones?
Old Sep 25, 2008 | 11:16 PM
UDAMON's Avatar
Car: Mazda Protege5
Front is all stock. Just the spindles.
Is a shock upgrade critical?
Old Sep 25, 2008 | 11:45 PM
rockit's Avatar
Car: 85 T/A, 92 Rs
Engine: L98:D,L03:<
Transmission: 700r4x2
Axle/Gears: 3.23 bw, 2.73 10 bolt.
prob could ge by on a new set of iroc springs, would stiffen and raise the front end a tad, old springsare most likely sagging and soft causing more problems.
Old Sep 25, 2008 | 11:49 PM
UDAMON's Avatar
Car: Mazda Protege5
Any idea on how much it would raise it? Keep in mind its a 3.1.
Old Sep 26, 2008 | 09:10 PM
Car: Too many cars
If your rear shocks are dead I would up grade to a better set, if not it may be bouncy.
front springs I would use V8 springs.
Old Sep 26, 2008 | 09:42 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
Leave it the way it is it looks so mean like that i love it i want mine to sit like that love that stance
Old Sep 27, 2008 | 09:21 PM
Fords88Bird's Avatar
Car: '88 Firebird Z20
Engine: 305 TBI w/TBI mods
Axle/Gears: Stock
Yea, no big issue if it only rubs at full lock. You could use some Moog 5660 or 5662 they have a higher spring rate and would bring you up probably an inch, ur pretty low man probably only 2 1/2" for pipe clearance. Why'd u decide on dropped spindles? If this is ur daily driver and u match the back to the front ur going to be draggin over something everyday. Later.
Old Sep 28, 2008 | 08:16 AM
irockid86's Avatar
Car: 88 iroc camaro
Engine: jasper 350, l98
Transmission: 700R4, corvette servo, shift kit.
Axle/Gears: stock
when i first got my car it was lowered from the previous owner. on the ride home from buying it, I must have scraped my air dam on the highway about 20 times. then when i got home and started looking, i realized that both inner fenders were worn throu in spots. in my opinion, lowered cars are not for the road. i would get some v8 springs ASAP you could even get some IROC or WS6 ones off ebay to lift it. I ended up getting some used springs from camaroheaven. cheep quick easy and they do the trick! good luck.
Old Sep 28, 2008 | 10:08 AM
18inchboyds's Avatar
Car: 1985 Trans Am
Engine: vee eight
Transmission: auto
Axle/Gears: 4.10 gears
too low in the front , raise the front a little with the springs , the rear could come down a little too but the front is too damn low.
Old Sep 28, 2008 | 11:36 AM
Axle/Gears: Stock
, and by the way I like the notchback. Later.
Old Sep 28, 2008 | 02:37 PM
88camaroluvr's Avatar
How much were those spindles? Where did you get them from? And, what type of modifications needed to be done and how much were the modifications in the long run? Thanks I really want to do something like this.
Old Oct 9, 2008 | 04:12 PM
UDAMON's Avatar
Car: Mazda Protege5
was having trouble deciding on what to do to raise the front. so for now i have coil spring boosters in and it actually worked out pretty well.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
88camaroluvr check out the racecraft ones. they should be a direct bolt in replacement.
http://www.racecraft.com/proddetail.php?prod=300106
Old Oct 9, 2008 | 05:11 PM
krisb410's Avatar
So you installed drop spindles to lower the car, then you installed coil spring "bosters" to raise it up
I'm not quit understanding why you installed the drop spindles then? How much drop did the spindles give you? And how much did the coil spring "booster" raise it?
Old Oct 9, 2008 | 07:13 PM
UDAMON's Avatar
Car: Mazda Protege5
do you not see the pictures???
worn out springs are the issue here. $8.99 is the cheapo fix.
Old Oct 9, 2008 | 07:31 PM
krisb410's Avatar
OK, so the boosters are just temp fix until you find the right springs to put in.
Old Oct 9, 2008 | 11:09 PM
Car: Too many cars
Dropped spindels are better than drop springs, or better dropped spindels with coil over setup like me.
Old Oct 9, 2008 | 11:36 PM
krisb410's Avatar
I put dropped spindles on my S-10, but I didn't realize he was using the booster just a quick fix, until he buys new springs.
Old Sep 16, 2009 | 06:56 AM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
Any updates on the car? Looks great with the front lowered! I don't think it's too low...it's great with a bit of the front tires inside the fender! Yes, the C6 rims with 2" spacers are a bit much for such a lowered car. Stock 16" IROC rims would be best. I'm sure it drives really well with it lowered like that! Actually, a back to front rake is good aerodynamically. I know guys would rather have a level 3rd gen, but if you look at all the newer hi perf. cars, they are slanted front to back with the rear higher....even most MB's and even the newer mustangs.
BTW, were those 2" drop spindles?
Old Sep 17, 2009 | 05:57 AM
Sinister Z's Avatar
Car: 1985 IROC-Z / Z-28
Engine: 383 C.I. Stroked 6.3 Litre
Transmission: 700R-4
Axle/Gears: 3:73 Posi
That's what i did to my car also I put in the dropped spindles years ago back in 1995 but last year when I added the eibach sportline springs it was waaay to low in the front so I had to add a 1" spacer but then I also cut a coil off of the back to help it even it out and it raised the front an additional 1/2".
So take a coil off the back now and it will sit nicely!
Old Sep 20, 2009 | 07:15 PM
UDAMON's Avatar
Car: Mazda Protege5
Heres an update. I figured id try a set of lowering springs- my reasoning is that typically they are designed for v8s. having a v6 and fiberglass hood, and being under the assumption my springs were worn out, i was expecting an amount of lift from the new springs along with a stiffer ride. also if i bought a new set (say over buying just new front v8 springs and cutting if they were too high) i would be able to drop the rear as well
well i went with dropzone springs mainly because of the price. after installing those the car sat even lower then in does in the first picture. its was bottomed out just sitting there.
so i just swapped out the homemade looking AJEs with my stock spindles and am more then happy with the results.
here is a picture with stock spindles and dropzone springs up front. still have to install the rears
and it rides much better now! the dips in the road that used to spell tragedy dont phase it anymore
oh yeah, i also swapped the 2" spacers for 1.5". tires arnt being cut by the fenders anymore, just have to be careful of rubbing at full lock
Old Sep 20, 2009 | 08:58 PM
polaris91's Avatar
Car: 88 camaro z28
looks nice what kind of spoiler is that?
Old Sep 20, 2009 | 09:36 PM
V6F1R3BRD's Avatar
Car: 1988 Firebird - 1998 Z28
Engine: 2.8 - LS1
Yes, let us know so we may mooch of your design. I know i will.
Old Sep 20, 2009 | 10:05 PM
UDAMON's Avatar
Car: Mazda Protege5
the wing is off a fiero actually, thanks!
Old Nov 15, 2009 | 11:21 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
O man i want drop spindles bad. I have Eibach lowering springs but i want AJE drop spindles and then 1.5" spring spacers to bring the front back to Eibach height. Spindles keep the correct suspension geometry. Right now my control arms sit flat... thats bad.
OK my questions:
What size are those rims (diameter and width and offset)? Do the drop spindles come near the inside edge of rim? Can u take pictures of the spindles and the clearances. PLEASSEEE. Thanks.
Old Nov 16, 2009 | 05:53 PM
UDAMON's Avatar
Car: Mazda Protege5
sorry dont have any more pictures of the spindles since i took them off.
wheels are 18x9 with a 7.00" backspace +50mm offset
from my experience i would have to guide you away from aje's spindles and suggest racecraft's spindles.
Old Nov 17, 2009 | 10:59 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok yeah ill probably go Racecraft. I was just wondering if they would raise the rim up too much that the spindle will rub the inside of the rim... i have 17x9 zr1s
Old Jan 18, 2010 | 08:13 PM
hellz_wings's Avatar
Car: 1986 Chevrolet Camaro IROC-Z28
Engine: TPI 310ci (LB9)
Transmission: Custom Rebuilt 700R4 - 2600 Stall
Axle/Gears: 10 bolt, 3.73 Eaton Limited-Slip
Good question... Will the racecraft spindles for stock style steering rub on anything such as the stock 16" IROC wheels with stock size tires as well as the wheel size he mentioned above?
Old Jan 28, 2010 | 02:54 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
anyone?
Old Feb 10, 2010 | 10:39 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Considering the RC Spindle are more improved over stock spindles, I do't see any problems occurring. Look for ebmiller's thread on the RC drop spindles in which he has made brakes kits and such to use on them, and has also gone in depth with the steering stops. He might know what will and won't fit.
This help? From RC description.
The spindles utilize C4, C5, LS1 factory brakes and any aftermarket brakes (Strange Engineering) that use a caliper bracket that bolts to the drilled and tapped dust cover holes on a factory spindle. These spindles include aluminum spacers for the factory strut flange.
Old Feb 10, 2010 | 12:58 PM
Yeah I got his ls1 brake kit... I will call up racecraft and get the info on this from them before ordering.
Thanks !
Old Jan 22, 2015 | 11:07 AM
vargasjc's Avatar
BEFORE:
AFTER:
I have a set of drop spindles from AJE I just got from a friend, What made the swap such a PITA In your opinion?? Anyone?
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
crazynights
Aug 21, 2015 06:53 AM
bryan623
Aug 10, 2015 11:33 AM
