NEW WHEELS BUT WHAT SIZE SPACERS???
Old Oct 5, 2008 | 03:35 PM
bmxerboi221's Avatar
Car: 1988 Firebird
Engine: soon to be 3.4/3400
Ok i just bought some 16'' 4th gen T/A wheels for my car for really cheap. Now i just need to know what size spacers to get so i can put these bad boys to work. Here is a picture with the wheels sitting next to the car to give you guys an idea of what they are gonna look like, also if anyone has any other pictures of their 4th gen wheels and spacers it would definately be a big help
Old Oct 5, 2008 | 03:41 PM
Stephen's Avatar
Car: 87 GTA
Re: NEW WHEELS BUT WHAT SIZE SPACERS???
2"..... http://skulte.com/
"In this case, we recommend 2" adapters for the front and rear. You can run the 2" adapters in the rear, even though you only need an extra 1.12" backspacing. This will move the wheel further out in the wheelwell, matching the front, and the wider track will help cornering as well."
Old Oct 6, 2008 | 08:21 AM
Car: 1988 Firebird
2'' in back wont cause them to stick out to far?
Old Oct 6, 2008 | 09:12 AM
Stephen's Avatar
Car: 87 GTA
I have no personal experience with running spacers/adapters. I've always had direct fit wheels.
Keep in mind, the rear wheels sit in farther than the fronts (stock). The wider than needed would give it a wider stance, look better & Skulte wouldn't recommend a size that would cause them to stick out.
Old Oct 6, 2008 | 11:01 PM
Pontiackid's Avatar
Car: trans am ws6
Engine: something special :)
Axle/Gears: 4.10 posi
yes you will need 2" spacers all around. I did this on my 91 formula when i put on some z06's. all 4th gen firebird/camaro wheels and vette wheels require the same amount of spacing. your wheels wont stick out to far in the rear, the same as stock.
Old Oct 7, 2008 | 06:57 AM
Car: 1988 Firebird
Ok cool thanks a lot guys!!!!!
Old Oct 7, 2008 | 03:31 PM
AmorgetRS's Avatar
Please read the stickies at the top of the the forum and any parent forum that you are posting in.
All questions regarding wheel fitment are supposed to be posted in the Chassis and Suspension section, not under the "Member Rides" subforum of Appearance and Detailing, as per this sticky:
https://www.thirdgen.org/forums/auto...ou-ask-if.html
I have moved the post there for you, even though you already have your answer, just to keep things clean.
Douglas
Amillionoh7
May 24, 2020 08:01 AM
toronto formula
Nov 10, 2015 06:17 AM
kah992
Aug 19, 2015 02:55 PM
knight72
Aug 10, 2015 09:32 PM
