10 spoke SS wheels won't fit
Old Oct 13, 2008 | 10:11 PM
wrsjr's Avatar
Car: 1991 Camaro RS
Engine: 355
Axle/Gears: 10 bolt Richmond 3.73 posi w/ discs
I tried bolting my my 10 spoke SS wheels tonight but they wouldn't fit on the rear. I have a 4th gen axle out of a 95 Camaro Z28. The center hole is maybe a tenth too small, actually probably less that that. Has anyone had this problem?
Old Oct 14, 2008 | 09:46 AM
ssean92's Avatar
Car: sold
Re: 10 spoke SS wheels won't fit
The center of the wheels has to be ground out some to get it to fit
Old Oct 14, 2008 | 10:36 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
I used a dremel and hand file, only a few minutes on each wheel, you don't have to take much off.
Old Oct 14, 2008 | 08:10 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
clean the rust build up off, then use some WD40...
Old Oct 14, 2008 | 08:43 PM
krisb410's Avatar
I doubt that would do it. 93 to mid 96, the center "Hub" of the axles were slightly larger then on the rest of the 92-02 axles. For some reason, I have 0.03 of an inch larger in my head, but I could be wrong about that number. Because it didn't come from an actual 1st hand measurement. But if it is correct, sanding the rust off the hub and wheel just might do it.
I still think you will need to grind the wheel though. I installed my rear (cleaned up, no rust) this summer, and my wheels only had a little rust on them. And I still had to dremel and grind a bit to get my 02 Transam wheels on my 95 rear. I plan on doing it with the front wheels too. It doesn't matter, because the wheels are lug centric, not hub centric. Plus, by just cleaning and WD40ing it, will make it harder to get off next time you have to take them off.
Old Oct 15, 2008 | 04:05 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
I did not know that. Will note it though.
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
kah992
Aug 19, 2015 02:55 PM
greeny
Wheels and Tires
Aug 12, 2015 03:55 PM
slade5612
Aug 11, 2015 07:19 PM
