Stock sway bar size on 92 RS?
Old Oct 7, 2008 | 08:36 AM
British Rich's Avatar
Car: 92 Camaro RS
Axle/Gears: Stock
What is the stock size of my front and rear Sway bars??
I want to get the bushings but have no means to measure it accurately....
Old Oct 7, 2008 | 08:39 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Stock sway bar size on 92 RS?
Use a crescent wrench on a couple of places on the bar, then measure the distance between the jaws.
JamesC
Old Oct 7, 2008 | 09:08 AM
Car: 92 Camaro RS
Axle/Gears: Stock
Given that 1mm makes a difference that doesn't sound very accurate to me.
Old Oct 7, 2008 | 10:08 AM
Car: 92 Camaro RS
Axle/Gears: Stock
PS - Didn't mean to sound ungrateful for the reply.
I guess I'll just have to buy some calipers.
Old Oct 9, 2008 | 05:07 PM
Xlr8torZ28's Avatar
Car: 1991 Z28 & 1992 Z28
Engine: LB9 & L98
Transmission: T56 & T56
Axle/Gears: 4.10s & 3.23s
I have the original factory assembly manuals from 82-92... I will look it up for you as soon as I get home.
Old Oct 9, 2008 | 09:20 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Look at your RPO codes and find the one starting with FE_ or F41 and let us know what it is.
Old Oct 10, 2008 | 02:04 AM
RacerX13's Avatar
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Should be 34mm front and 21mm rear.
You can also wrap a strip of paper around the bar, mark a line across it, lay it out flat and measure between the marks with a ruler, divide by 3.14.
Old Oct 10, 2008 | 02:23 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
My car was a F41, and it had the 34/21 combo. Now it's 36/24 lol
Old Oct 10, 2008 | 02:50 PM
sid rs91's Avatar
Car: 91 RS TBI 91 Z28 TPI
Transmission: wc T5
I know that 36/24 seems to be the magic combo for most guys but just wondering did you notice much of difference when you switched from 34/21( this is what my car has).
Old Oct 10, 2008 | 02:54 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
The front end defintatly firmed up alot. A better feeling of control and less body roll. The rear went from 21 to 25. The 25 was way too much rear bar, so I went to the 24. The car is pretty nuetral with this combo and I like the feel of in cornering. If I still had the 21, I'd try it out and see how it works, but I trashed in a moment of stupidity.
Old Oct 10, 2008 | 02:57 PM
freestylzz's Avatar
Car: 1987 Iroc Z28
Engine: The KING of the 3rd gen TPI's.
Transmission: Beefed up T5
Axle/Gears: Aussie 3.45's
FE1 F-30 R-18
F41 F-34 R-21
FE2 F-36 R-21
Old Oct 10, 2008 | 03:01 PM
sid rs91's Avatar
Transmission: wc T5
Thanks 91_5.7_TPI. Think I will go head and upgrade too, will try 36/21 combo just for kicks .
British Rich, sorry for hijacking your post. Where in England you from I'm from midlands originally.
Old Oct 10, 2008 | 04:38 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
Here it is straight from GM.
This is for 1991... I'll dig the 1992 book out later
FRONT
30mm solid RS
34mm hollow RS w/ 16" wheels & base Z28
36mm hollow Z28
(I assume the 36mm listed was for 1LE option.)
REAR
18mm RS
21mm RS w/ 16" wheels & base Z28
23mm Z28
Old Oct 13, 2008 | 06:10 PM
Car: 92 Camaro RS
Axle/Gears: Stock
Thanks guys - so my calipers were close (although getting the same reading twice was a PITA LOL)
I def have the 34/21 combo - I think with poly bshings that is plenty formeas I don't AutoX etc
Hey sid, from Oxford, born and raised! What about you, are you a brummie? LOL
(isn't it nice having these ridiculosly oversized, giant engined cars??? Could never do that in England. People that do are mental, the roads are WAY too small!!!!)
Old Oct 14, 2008 | 08:39 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
NAPA offers a bad *** little set of end links for the sway bars... $24
http://www.napaonline.com/masterpage...ear+Suspension
Old Oct 14, 2008 | 09:20 PM
sid rs91's Avatar
Transmission: wc T5
yeah you could say I'm a brummie, spent enough time there but from Walsall.
Went back there for a visit a few ago and saw 2 fbody's.One drove by and it barely got down the street we were on! LOL.
Old Oct 14, 2008 | 09:33 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wow, that is a nice looking set of endlinks. I may go that route next time. They rubber or poly?
Old Oct 15, 2008 | 03:41 PM
Xlr8torZ28's Avatar
Engine: LB9 & L98
they are poly, and they are alot wider than all the aftermarket stuff I have seen.
Old Oct 15, 2008 | 04:09 PM
JamesC's Avatar
They appear to be very similar to GM's 1LE links. I used them for a while, but I didn't like the way they fit the sway bars. The ES versions seems a better match, IMO.
JamesC
1992rs/ss
Jan 31, 2025 05:10 PM
Frozer!!!
Jan 19, 2024 04:55 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
1992rs/ss
16
Jan 28, 2016 09:58 PM
toronto formula
Nov 10, 2015 06:17 AM
