lowering springs with no rake???
Old Oct 17, 2008 | 07:09 PM
dspencer24's Avatar
Car: 91 z28
Engine: 350/ported accel tpi/AFR 195
Transmission: t-5 =(
Axle/Gears: 345
its time to buy lowering springs. does any one have any pics of vogtland springs on there car?? or hotchkis? i want the height to be in between the prokit and the the sportlines?
Old Oct 19, 2008 | 01:25 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
Re: lowering springs with no rake???
any ideas? i have tried to do research on vogtland but i havent found anything yet so im going to give them a call ask for pics..
Old Oct 19, 2008 | 01:45 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
whats the lowering rate on them? how much drop?
Old Oct 19, 2008 | 06:20 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
its supposed to be 1.2 " drop front and back
Old Oct 24, 2008 | 12:16 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
anybody??
Old Oct 24, 2008 | 01:41 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
hmm i dunno i have the eibachs idsay just go with a good name in performance that way they will last forever and not give out. and i think they have the same lowering height mine is about 1.2 or something. front and rear
Old Oct 26, 2008 | 12:31 AM
86irocterror's Avatar
dont quote me till you get a deffinate answer but i think the vogtland springs are soft. i would just get a pro kit. anything more is a pain in the but to drive. i had sportlines and went to the prokit.
Old Oct 26, 2008 | 10:13 AM
Stephen's Avatar
Car: 87 GTA
Get the Ground Control weight jacks, and you can select the spring rate you want & decide what ride eight is right for YOU, & change the ride height later, without buying new springs.
Or if you decide you want stiffer or softer springs, you can do that too, & still adjust the ride height were YOU want it to be.
Old Oct 26, 2008 | 05:55 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
well right now i have the 1le springs i believe and they are pretty stiff and i dont want anything stiffer then those. i will probably ending with the prokit but i want to weigh other options. How are hotchkis???
thanks for the replys and i will take a picture of my car on level ground so you guys can see how how it sits now
Last edited by dspencer24; Oct 26, 2008 at 05:57 PM. Reason: Automerged Doublepost
Old Nov 11, 2008 | 04:26 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
this is the how the car sits there is a slight dip towards the sidewalk.
Old Mar 17, 2009 | 01:38 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
anyone ????
Old Mar 17, 2009 | 03:12 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
If the rear sits too high, you can remove the rear spring isolators, and put a section of garden hose around the top coil. Lowers the rear about 1/2" to 3/4".
Old Mar 17, 2009 | 03:38 PM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
i really dont see a difference in the way the car sits. i noticed a slight gap difference in my rs but that was before i redid the whole suspension....
anyways im sure hotchkis or eibach would be great. do a search on the hotchkis springs im sure someone did a aftermarket review on them.
I put on the prokit and i love em. not too much lowering and handles great. the rear has a slight gap between the tire and fender but im gonna do what he mentioned ^^^ and take out the thick coil to frame seperators out to give the rear that slight extra drop...
good luck!
Old Mar 17, 2009 | 03:50 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Definitely the Pro Kit, Not to soft, not to low. But what about B&G?
My plan is to hopefully lower my car to where the top of the tire is level with the fender lip, giving no gap between the tire and fender well. i dont want to tuck them inside but just level with the fender lip. I think I can acheive that with about a 1.5" drop, might remove those isolators as well, we will see.
B&G States a 1.6" drop front and rear, but no spring rates. I think they are softer than the pro-kit?
http://b-gsuspension.com/displayResults.php5
Old Mar 17, 2009 | 07:16 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
good luck!
Can you take some pics of your car with the stock rims with the prokit? I want to lower my car about 1-1.3 inchs all the way around. I was looking into the summit springs to but cant find to many pics of them installed
Old Mar 20, 2009 | 03:02 PM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Why the hell didnt one of us senior members post this.
Check this thread out, pictures and just about as much info we have on lowering springs for our cars.
https://www.thirdgen.org/forums/susp...ing-101-a.html
Scroll down in the first post, you will see the drop rates (proven drop rates) as well as their owners pictures. I want to go about the drop of dropzones but with a higher spring rate. Something like 800lb in front with a 250 in the rear. Might look into weight jacks and adapt for street use.
Edit: Just got back from the Auto Show and saw 2 camaro's with Sportlines with the rake look. I liked how low the car was in the front but didn't look good in the rear.
Old Mar 24, 2009 | 09:10 AM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
thanks but the guy with the candy red paint doesnt look like any other pro kit. Is there anyone with stock rims and the pro kit? or any other type of 1" drop springs
Old Mar 24, 2009 | 09:35 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
why not just get tires that are smaller - height wise. the standard is 26 inches - so go wider and get 25 inches of height - that drops you down 1/2 inch.
Old Mar 24, 2009 | 11:22 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
Axle/Gears: 10 bolt w/ 4.10 gears
while that is technically correct, the most noticable change when you lower a vehicle (via different springs) is that the gap between the fender and tire gets smaller. By reducing the tire diameter by 1", you lower the car by .5" and increase the wheel to fender gap by .5" also, so the car may actually appear to be higher than it was before. That's why I considered using 1" taller tires along with my pro-kit. I would have nearly stock ground clearance and sportline-like fender gap.
Old Mar 24, 2009 | 10:41 PM
dspencer24's Avatar
Car: 91 z28
Axle/Gears: 345
you have the right idea im going for fender gap. What size tires do you have?
Old Mar 26, 2009 | 09:18 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
what do you mean by "rake"? im assuming how the wheels drop into the fenders a bit. anyways, i dont have the stock wheels on anymore i upgraded to 18" IROC's and they look great all around excellent in the front the rears could be better so im going to take out the hard plastic coil dampners and put some rubber gasket or gardening hose to get that little drop that it could use and im sure after that ill have the great drop handling and the looks as well. hope you get a better idea overall now.
Old Mar 26, 2009 | 10:23 AM
JeremyNYR's Avatar
Car: 1984 Trans Am
dspencer24, I still have original size 245/50r16. I was considering going to 18" rims and getting tires with an overal diameter of approximately 27" rather than the stock 25.6". Turns out I'm staying with the 16s though.
samiam91rs, rake usually refers to when a car is lower in the front than it is in the back. I found my original springs to make the car higher in front and lower in back and going to the pro-kit all around leveled it out. I may have just had saggy rear springs though.
Old Mar 26, 2009 | 10:59 AM
Stephen's Avatar
Car: 87 GTA
My stock springs sat me at 26" front, 27" rear, ground to fender lip edge.
Old Mar 27, 2009 | 11:31 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
I'm going to check mine today just to see, since its been sitting for 2 1/2 years. I'd like to know where its sitting now.
Bubbajones_ya
Jul 6, 2024 08:32 PM
Lanz06
Sep 14, 2015 07:16 PM
crzycamaro86
Sep 12, 2015 05:51 PM
Thornburg
Sep 12, 2015 10:11 AM
lakeffect2
Sep 7, 2015 03:52 PM
