Wheel Fitment ?s
Old Oct 19, 2008 | 01:18 PM
Seanmay1's Avatar
Car: 89 Firbird Formula WS6
Engine: TPI 305
Transmission: T 5
Axle/Gears: 3.45 Posi 9 bolt
Wheel Fitment ?s
Thinking of running these on my car so i can run bigger brakes, they are 18x8.5, how thick of a spacer would i need to run? Can i run longer studs and just get a cheap spacer or would i have to get the spacer that is like an adapter? Oh and its for a 89 Firebird Formula
http://www.lakeshorewheelandtire.com...als/c6-b.shtml
Old Oct 19, 2008 | 03:49 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Wheel Fitment ?s
you would need the spacer/adapter things, really long studs and just a solid spacer would be asking for trouble.
Usually its a 1.5" or 2" spacer, depending on the offset
Old Oct 19, 2008 | 04:12 PM
Seanmay1's Avatar
Engine: TPI 305
Transmission: T 5
Cool thanks for the tip about the spacers, I guess i need to find the offset for those wheels, and compare it to the factory 16s and try to get it close to that then right? What is the back spacing on the 16x8 factory wheels?
z 28 jari
Sep 14, 2021 10:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
Chad Speier
Sep 24, 2015 12:32 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
