No one mentioned this? (for a-arm removal)
Car: 92 Camaro RS
Axle/Gears: Stock
So I got everything set up to pull my a-arm out today to find out that the bolt for the front a-arm bushing doesn't come out unless you undo the tie rod.
Not a big deal but when you were not prepared for that (eg, pickle fork and new bushings) it pretty much f*cks up ur day.
I never saw this mentioned anywhere in my research before I got under there ;(
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: No one mentioned this? (for a-arm removal)
i never had to remove the tie rod.
Car: 92 Camaro RS
Axle/Gears: Stock
Not trying to blame anyone, just putting it out here so someone else might see it BEFORE they have the same crappy day LOL
Car: 92 Camaro RS
Axle/Gears: Stock
Yeah I wasn't expecting that at all, but on mine the joint sits directly in front of the head of the bolt with about a 1.5 inch gap...no way to get that 3-4 inch a-arm bolt out that way.
I am wondering if they were done before and the bolt was put in the wrong way round. If the head was facing the other way it wouldn't matter.
I guess I'll be buying tie rod bushings very soon LOL
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
If I remember correctly, you can man-handle the spidle out of the way enough to get the tie rod to clear the bolt. You also have to turn the wheel to one side or the other depending on which side your on. At least I think you can do that.
Car: 89 Camaro/ 02 GC Overland
Engine: 355 V8/ 4.7 HO V8
Transmission: T5/ 545RE
Axle/Gears: 10 Bolt 3.73/ Dana 30, Dana 44 3.73
I always just turned the wheel full lock to one side and it moved out of the way enough to loosen and pull the bolt out.
