How much should it cost
Old Oct 20, 2008 | 01:49 PM
goomaan's Avatar
Car: 1987 IROC-Z
Transmission: 700R Auto
Need advice:
To install all UMI SFC (weld only), Panhard Bar, Lower Control arms, Wonder Bar and Moog Springs all around (mechanic suppling Moog springs) how should that cost?
Old Oct 20, 2008 | 03:35 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: How much should it cost
To install my SFCs and LCARBs it was $120. I'd say for all that it would be something around $300-400 depending on the area. If you have basic hand tools, flat floor (concrete/ashpault) and a jack, you can do the panhard bar, lower control arms, rear springs, and wonder bar without much trouble. The front springs will be more difficult due to the design of the suspension.
Old Oct 20, 2008 | 04:26 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
As long as you have a set of metric sockets, a ratchet/breaker bar and torque arm, you can very easily do the PHB and LCA in you garage/driveway in one evening. This will probably take about 1.5-2 hours.
The wonder bar takes all of 20 minutes to instal/swap if you have the tools mentioned above.
If you have a decent MIG welder (and if you know how to use it) you could also easily do that in your garage/driveway. The time it takes depends on how thorough you are.
Springs can be done if you go to Autozone (or some place similar) and rent a spring compressor, or if you buy your own. If your doing springs, you might as well do the shocks/struts and strut mounts at the same time since all that will be apart. The fronts take some time but the backs are pretty straight forward.
Mike
Old Oct 21, 2008 | 08:26 AM
goomaan's Avatar
Car: 1987 IROC-Z
Thanks for the responses.
A shop by me was quoting $1350 for all the work. Totally @$%%#@^%#%#
FYI: Already replaced the shocks and struts all around when I did the J&M stut mounts. Have KYB adjustables.
Old Oct 21, 2008 | 11:13 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I'm not a mechanic by profession or nature and I'm unsure of when I discovered my DIY side (which is quite satisfying), but most of the upgrades you mention are simple unbolt, bolt-ups that you can do yourself. Save some dough and buy other goodies instead of the mechanic.
The springs are another matter. If you're unexperienced, I'd suggest extreme caution or a good dental/medical plan.
JamesC
Old Oct 21, 2008 | 09:19 PM
Joez88Camaro's Avatar
Car: 1988 Camaro Sport Coupe Convertible
Engine: Your Momma
Transmission: I can go forwards and backwards
Front springs and welding aside the rest if very simple in/out kind of stuff for a DIY'er. Let them do the fronts and the SFCs.
The trailing arms, wonderbar, and Panhard rod can be done without a jack and a can of redbull in 30 minutes if your racing. The rear springs you'll have to jack it up though, lol.
Old Oct 22, 2008 | 05:01 PM
Car: 1987 IROC-Z
Transmission: TH350
You could also take out the carpet yourself so that will save you some money if you have someone else weld them in.
Old Oct 22, 2008 | 06:12 PM
JamesC's Avatar
No need to remove the carpet. Remove the door sills and put something between the carpet and floor pan. Keep watch but you should be fine.
JamesC
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
TheCardinal
Exterior Parts for Sale
Oct 1, 2015 07:40 PM
Damon
Sep 26, 2015 04:29 PM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
