Front & Rear???
Old Dec 1, 2008 | 01:21 PM
MYZ28NH's Avatar
Car: 91 Z28 Convertible
Front & Rear???
Guy's I just bought a 1991 Z28 with stock wheels. The tires on the wheels are all dryroted. I found a good deal on some older Iroc rims with good tires so I bought them. Everyone who posted said the wheels were all interchangeable. I am in the process of fighting to get the factory lock nuts off so I can swap the wheels. The special tool to remove them did not stay with the car. So removing these nasty things has become my new problem.
Anyway, I see the stock wheels are marked front and rear. The wheels I bought are not. Am I going to have a new problem when I put these wheels on?
Old Dec 1, 2008 | 01:36 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Front & Rear???
As far as I know, all IROC wheels are marked front and rear. Check my Car Details below for a pic of the single stripe version, 85-87, IIRC. The newer version was two stripes.
JamesC
Old Dec 1, 2008 | 05:48 PM
MYZ28NH's Avatar
Re: Front & Rear???
Well the one's I just bought are not. I mounted them and they ride just fine.
Old Dec 1, 2008 | 06:33 PM
JamesC's Avatar
Re: Front & Rear???
I'd like to see pic--I can't believe the IROC wheels aren't labeled front/rear.
JamesC
Old Dec 1, 2008 | 06:41 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Front & Rear???
Are they 16" or 15"?
Old Dec 1, 2008 | 06:45 PM
Stephen's Avatar
Car: 87 GTA
Re: Front & Rear???
BINGO! Th 15"s are not front/rear specific, only the 16" ones are.
Old Dec 1, 2008 | 06:50 PM
JamesC's Avatar
Re: Front & Rear???
Interesting. Speedo problems?
JamesC
Old Dec 1, 2008 | 07:26 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Front & Rear???
Not if you use the same tire diameter.
Old Dec 1, 2008 | 08:43 PM
JamesC's Avatar
Re: Front & Rear???
True, but will the original poster be that lucky?
JamesC
Old Dec 2, 2008 | 12:16 AM
MYZ28NH's Avatar
Re: Front & Rear???
Yes they are 15's...and I am that lucky. The wheels are an 1" smaller but the tires on them are a little bigger. The fronts are 215 65R 15 and the backs are 225 50R 15 they appear to have the same height as the stock wheels only not as wide.
Old Dec 2, 2008 | 12:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Re: Front & Rear???
Those are Z28 wheels, not IROC wheels. Although they were available as an option on IROCs.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Reddeath210
Oct 6, 2015 08:20 AM
MORREALE5
Sep 13, 2015 09:16 PM
