bushing replacement or full front end?
My 1988 Camaro has rather loose steering. The slightest ruts in the road cause it to pull in either direction. I am wondering if replacing the bushings would be enough to stiffen it up again or should I invest in a new front suspension all together?
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
Re: bushing replacement or full front end?
first of all inspect steering linkage & ball joints . fix what is bad , a full rebuild is not that big a thing . it is a BIG safety factor . if you drive with a loose/sloppy front end you are just asking for trouble . if you are not sure , take it to a local alignment shop . most will point out what is bad and show you . don't be afraid to ask , all they can say is no . if you do the work yourself you will need an alignment . just try to keep dimensions on linkage the same . then get an alignment . do not drive it alot , just to alignment shop . good luck .
Car: 84 z28 Camaro H.O
Engine: l69
Hey im having the same problem with my 84 camaro (exactly) like you described. I just purchased a full energy suspension kit for rear and front but i have not put in on yet hopefully this will be the problem..
I also have a pop (clunk) on both left and front (lower) end suspension when i am braking, just about when im gonna come to a complete stop. does anybody know what this can be???
Last edited by 1984z28camaro; Dec 8, 2008 at 07:59 PM. Reason: Automerged Doublepost
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
