Shocks and Struts and Springs or Torque Arm
Old Dec 9, 2008 | 06:10 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Transmission: T5 non-W/C
Axle/Gears: 3.27 Open
as you all know christmas is coming up soon and I believe i've convinced my parents to buy me front Koni Struts. Since there expensive i'm going to buy the rear shocks. And I decided that while everythings apart I am going to get springs also. I'm going to go with Moog Performance Replacement Springs.
My question is should I get the rear shocks and springs, or should I get a Spohn toqure arm??? I know the biggest problem with my handling right now is shocks and rear traction. My little 305 likes to make the back end a little squirly. So should I get the $415 torque arm while I have the cash or should I get the shocks and springs?
Old Dec 9, 2008 | 06:29 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Shocks and Struts and Springs or Torque Arm
Shock and springs. Complete this area, struts/shocks and springs, before moving on to other suspension up-grades.
JamesC
Old Dec 9, 2008 | 06:30 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
ok. Your very convincing.
Old Dec 10, 2008 | 09:39 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Shocks and springs to the 5th power.
The torque arm will help, but it won't do much if your shocks are shot and your springs are 17+ years old.
Old Dec 11, 2008 | 01:17 AM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
+1 for shocks and springs
I'm sure the torque arm will help, but the Koni's and new springs will truly be a night and day difference! At least they were on my car.
I'm trying to get my parents to give me the money for LS1 calipers and rotors for my brake upgrade in the spring.
Old Dec 11, 2008 | 09:10 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Shocks/Struts/Springs > Torque Arm
Old Dec 11, 2008 | 04:54 PM
Josh R's Avatar
Car: Iroc
Engine: 350 4-bolt
Ok can i use Konis with Moog Springs with no problems? I heard you need to buy your springs and shocks as a group that are mnade for each other.
Old Dec 11, 2008 | 05:03 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
The KONIs will work with the Moogs. They are adjustable. The shocks with for certains springs are usually sold in sets.
Hotrodboba400
Dec 10, 2019 07:07 PM
J-money
Jan 4, 2019 09:45 AM
New2Chevy
Sep 28, 2015 12:35 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
