camber plates
Old Jan 21, 2009 | 10:33 AM
Twin_Turbo's Avatar
camber plates
Does anyone have, or can anyone provide me with a sketch/drawing of the camber plates and the stud locations? I want to make a custom tower brace and want to sandwich the baseplate under the camber plates. Problem is, I don't have the dimensions needed to design it in Solidworks and send it off to the laser cutter.
Anyone have a set of spares they could measure?
Thanks,
Marck
Old Jan 21, 2009 | 02:17 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: camber plates
You don't need camber plates on a 3rd-gen. Nor' caster plates. The caster and camber adjustments are easily made with the stock upper strut mounts.
RBob.
Old Jan 21, 2009 | 02:30 PM
Twin_Turbo's Avatar
Re: camber plates
That's what I mean, those strut mounts. I want to sandwich a plate between that and the body so I can build a brace between the 2 towers. I don't want to use aftermarket stuff, I want to build my own with stainless steel. However, for that I would need to know the dimensions of the strut mount and the exact location of the 3 studs.
Old Jan 21, 2009 | 03:16 PM
Stephen's Avatar
Car: 87 GTA
Re: camber plates
I have a pair of strut mounts sitting right here, but my scanner is giving me fits.
Old Jan 21, 2009 | 06:38 PM
Stephen's Avatar
Car: 87 GTA
Re: camber plates
Will these work for you?
Old Jan 22, 2009 | 05:22 AM
Twin_Turbo's Avatar
Re: camber plates
Yes, perfect. Only one measurement is needed to get it right, the exact distance (horizontal in that pic) between the 3 slots, that way I can orientate the triangular measurements of the 3 studs in relation to the direction of the slots.
Marck
morrow
Jan 13, 2024 12:29 PM
loud91rs
Oct 5, 2015 10:05 PM
ndndndnd
Sep 28, 2015 08:00 AM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
