stock style suspension
Old Jan 29, 2009 | 09:06 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
im just kinda wondering what kind of time people are laying down with a stock style suspension. so stock style no back halves or four links
let me know what ya run with a torq arm and nine inch
Old Jan 29, 2009 | 09:43 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: stock style suspension
I run 9.5's @ a 3650lb race weight with 90/10 struts, front drag springs, strange dana 60, 50/50 shocks, spohn trans mount tq arm set at -2.5 degrees, lakewood LCA's, and set to the 3" drop on the LCARB's. Car has to have a 28" or taller drag radial to hook it, but does about a 12" wheelie as shown in my avatar launching off the trans brake at 4500rpm. This suspension setup is so good that it hooked a set of 26" tall BFG radial t/a's with my old 305 to a 1.8 60'.
Old Jan 30, 2009 | 08:36 AM
greezemonkey's Avatar
Car: A Portly 85 Z28
Engine: 4.530 X 4.250 BBC
Transmission: under rated for this application
Axle/Gears: also under rated
have a friend in the 8.80`s, I`ll be there in the spring..9 teens so far
Old Jan 30, 2009 | 09:50 AM
stiletto's Avatar
Car: 85z28
Engine: sbc
Transmission: th400
Axle/Gears: 3.80 gear 35 spline axles
there is a car in north florida hour and a half north of me that runs 7.33 190 + mph on stock style suspension and troy pirez runs 7.50 at 180+ with almost the same set up
here is a pic of the 2 cars
Old Jan 30, 2009 | 08:39 PM
ziggy89's Avatar
Engine: 383
ok that answers the question then
Old Jan 31, 2009 | 08:37 PM
Lonnie P's Avatar
Car: 91 Formula
Engine: 2012 LS9
Transmission: 4L80E
Axle/Gears: Strange 60 3.54:1
I've seen cars lay down 60ft times in the 1.2's on drag radials, non tubbed. Set up properly, they work quite well.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
LT1Formula
Nov 16, 2015 01:13 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
TheExaminer
Aug 25, 2015 07:34 PM
