What rear end is this?
Old Feb 3, 2009 | 10:15 AM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
http://seattle.craigslist.org/kit/pts/1018574761.html
The seller didn't know what size the ring gear is, or what the ratio is. Do any of you? Apparently it's a 10-bolt.
Old Feb 3, 2009 | 11:40 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: What rear end is this?
Get onto a parts supplier website and search for the parts (ring gear, etc) for the rear end for that year/model car. Might also be able to find the stock gear ratio that way as well.
Old Feb 3, 2009 | 11:46 AM
BMR Sales's Avatar
Former Sponsor
If its a 94 10 bolt its a 7.5" RG not sure about the gears
Old Feb 3, 2009 | 12:15 PM
jermdm's Avatar
Car: 1989 Iroc-z
Transmission: Auto 700R4
Axle/Gears: 9 bolt - 2.77
No way to tell what the gears are without knowing the #'s on it. It looks like that rear end is out of a monte carlo or caprice.
Old Feb 3, 2009 | 12:40 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
It's from a 94 Caprice, and I assume it's the same ring gear as the F-bodies, but I would rather him check to be sure.
Old Feb 3, 2009 | 05:36 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
When I emailed the seller all he knew is basically what you can see in the ad. If it had a larger ring gear, and since it has disc brakes and posi, I would have been interested. Oh well.
Old Feb 3, 2009 | 08:53 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Even if you bought it, you'd need to do some fab work to get the suspension to hook up to it.
Old Feb 3, 2009 | 10:22 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
Yes, I understand this...
but for rear disc brakes and posi I'd be willing to spend a little time with a grinder a welder. Just not for a 7.5"ish ring gear.
Old Feb 4, 2009 | 09:41 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Wonder if you could just swap over the stuff from that rear to yours? I spent $300 on the rear in my car. Went from a 2.73 open to a 3.27 posi with disks.
Old Feb 4, 2009 | 10:13 AM
BMR Sales's Avatar
Former Sponsor
What kind of driving are you going to be doing with the car? If its an auto you should be good into the high 10 second range as long as youre not leaving on the brake or anything like that.
Old Feb 4, 2009 | 04:55 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
I have access to a 9" with 3:73's, and a powertrax locker, built to use all stock suspension components, but it has drums, but I'd be willing to sacrifice a little of that strength for having rear disc. I was just thinking that if this rear end wasn't as weak as the stock ones, it might be cheaper to buy that and use it, rather than convert a 9" to disc brakes.
Old Feb 4, 2009 | 05:00 PM
BMR Sales's Avatar
Former Sponsor
How much is it going to cost to convert it? Check this thread out, it might help...
http://www.pirate4x4.com/forum/archi.../t-121194.html
Old Feb 4, 2009 | 05:01 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
That rear end ring gear is a 8.5, no where near compatible with a thirdgen. Also, the Posi in those weren't very good at all. My bet is the posi is toast already.
Old Feb 4, 2009 | 05:25 PM
superT's Avatar
Car: 1985 camaro z28
Engine: 355 sbc what else
Transmission: TH 350 manual vb/ 4200 stall
Axle/Gears: 4:30 on the street
looks like a 7.5 out of a g-body (monte, malibu, cutlass, etc.) and i believe that they were all as weak as the ones in the f-body. buy a 12 bolt from moser and never look back most of those came with 3:08 but was optional with 2:73, 3:42, and maybe the 3:23 but not sure
Old Feb 4, 2009 | 05:33 PM
Bullydawg's Avatar
Car: 88 Formula 350
Engine: 5.7
Axle/Gears: 9" 3.89
The title says "parting out 94 caprice police car"... So I am going to say it is safe to ASSUME it is out of a caprice. Which is a 8.5" ring gear.
Old Feb 4, 2009 | 10:53 PM
superT's Avatar
yeah sure does, well '94 caprice it is
Old Feb 5, 2009 | 09:12 PM
gregsz-28's Avatar
Car: 85 Camaro
Engine: No
Transmission: No
Axle/Gears: No
The seller said the ratio appeared to be about 3:10, so I assume it's 3:08.
Anyways, after finding this kit:
http://www.speedwaymotors.com/BOLT-O...FORD,5336.html
, I think I've settled on the 9".
(the one with the provisions for parking brake) $449
Old Feb 5, 2009 | 09:17 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
In the end, my last girl settled on the 9" as well.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
