GM Style II Power Steering pump
Old Feb 6, 2009 | 10:19 PM
The_Phoenix's Avatar
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Is it possible to swap in a GM type 2 style power steering pump such as the one pictured, to replace our saginaw style ones?
Thanks,
Ruben
Old Feb 10, 2009 | 03:12 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Re: GM Style II Power Steering pump
Anyone? The reason bieng that my P/S pump is giving out and would like to replace it with this particular unit (pictured) before I decide to go with a stock saginaw pump. What about the shaft sizes, do both style units have the same shaft diameter?
Thanks in advance,
Phoenix
Old Feb 15, 2009 | 12:54 AM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
yes it can be done - you'll need a remote reservoir, pulley and bracket. heres a link to some type two brackets
http://www.alangrovecomponents.com/Power_Steering.htm
Old Feb 15, 2009 | 12:57 AM
FueledSoul's Avatar
sorry i was thinking 4thgen with the remount mount... what one is that pictured?
Old Feb 15, 2009 | 11:13 PM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Cool thanks FueledSoul . I figure I'd ask before I played guinea pig for this swap . A bit on a side note, FS, now that you mentioned the Alan Grove brackets, have you used them before? would you happen to know which particular bracket set would fit my TPI L98? As for the type II power steering bracket, would I have to modify the stock alt./ps bracket in order for this one to fit? The pump you see pictured in my 1st post is from detroitspeed.com: http://detroitspeed.com/productpages/steeringvar.htm it comes with a clip-on plastic reservoir which closely resembles our stock saginaw pumps only more 'updated' looking lol.
Thanks again for the info,
Ruben
Old Feb 17, 2009 | 02:06 AM
Car: Don't
Engine: have
Transmission: it
Axle/Gears: anymore
Originally Posted by FueledSoul
yes it can be done....
sorry i was thinking 4thgen....
So can I or can't I? lol
Later,
Phoenix
Old May 18, 2021 | 12:22 AM
drb930's Avatar
Car: 1987 Chevy El Camino
Engine: 357 CID w/Lingerfelter Super Ram
Transmission: 700-R4
Axle/Gears: GN 8.5 342's
Wondering the same question?
P/S Type-2 into L98 with stock serpentine belt setup.
WASyL
Nov 1, 2013 10:45 PM
mw66nova
May 15, 2012 11:07 AM
afida15
Fabrication
Feb 21, 2008 11:17 AM
B4Ctom1
Apr 26, 2005 11:00 PM
notaustin83z
Apr 28, 2004 12:53 AM
