ATI procharger owners: Power Steering Pump Solution
Old Apr 24, 2005 | 04:55 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
since the head unit sits right on top of the power steering pump blocking acess to the filler. I have been thinking about this since the first prochrger I ever installed. I knew they existed, but couldn't remember on what car lines.
I haven't seen one of these for a while, I figured since I actually found a source for them in the wrecking yards, that I should share it.
It is the GMC Safari and Astro in the original body style (late 80's early 90's)
I was getting a steering shaft from this safari for another project when I spotted that it has a power steering pump with the divorced resevoir.
Meaning that instead of filling on top, it fills separately with a resevoir that has its own dipstick. This resevoir supplys the pump with fluid at the top of the pump. From what I remember about these they have the same sort of "bolt-up" holes and studs on the body as the rest of the GM line (like ours) to go on our brackets.
Unless someone actually goes and graps one, installs it on a third gen we wont know what extra detail it might entail. It seems a straight forward swap to me.
whomever does it will need a "PS pump" pulley puller.
here are the two crappy cell phone pictures I took:
the resevoir
Attached Thumbnails ATI procharger owners: Power Steering Pump Solution-04-23-05_1305.jpg
Old Apr 24, 2005 | 04:56 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
and the pump
Attached Thumbnails ATI procharger owners: Power Steering Pump Solution-04-23-05_1307.jpg
Old Apr 25, 2005 | 12:09 PM
LimaBravoNiner's Avatar
Car: 89 GTA, 89 Formula
Engine: L98, LB9
Transmission: Auto, 5-Speed
Turbo Buicks use a separate reservoir also (at least in 86-87). Not sure if the pump would bolt up though.
Reservoir is still avaialable, P/N 25531140.
Old Apr 25, 2005 | 12:32 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
I bet it would bolt up. Im sure that a minivan junkyard pullout beats a Grand National "new in box" part for prices any day.
Old Apr 25, 2005 | 12:42 PM
Engine: L98, LB9
He He He, you're probably right.
gmpartsdirect has it for $16.50, GM list is $29 (without cap, of course)
I just thought I would offer it up as an option because it is a completely different design than the one in your pic from the van. May or may not lend itself better to a 3rd Gen application.
Old Apr 25, 2005 | 12:46 PM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
good idea
Old Apr 26, 2005 | 02:18 AM
83 Crossfire TA's Avatar
Not as likely to be a cheap JY find but many mid 90's and up GM's use them, including the vettes, anything powered by an LT1, caviler/sunfire a bunch of the midsize cars… A bunch of these will use the newer/next design pump which will require some adaptor fittings to mate up to the 3rd gen plumbing/box, but the point is that there are tons of options.
Old Apr 26, 2005 | 02:44 AM
B4Ctom1's Avatar
Veteran: Air Force
Car: 1992 B4C 1LE
yeah, I liked this car for the idea, it is a cheap and likely candidate for fitment here.
But those cars might make goot alternate donors for the resevoirs with alternate styles of resevoir brackets.
Old Apr 26, 2005 | 11:00 PM
the newer ones use a small square reservior that should be easier to retrofit then a round one.
Vintageracer
Jan 10, 2020 05:33 PM
colton_carlson
Mar 8, 2019 12:21 PM
MoJoe
Sep 15, 2015 12:50 AM
backtothe80s
Sep 5, 2015 12:39 AM
85Iroc-Z
Aug 13, 2015 01:58 AM
