What is the Right Pinion Angle?
Old Feb 20, 2009 | 05:47 PM
wdigitog's Avatar
Car: 1983 z-28/SFC/bilsteins/adj.arms
Engine: 355sbc/Demon650dp/hedmanheaders/
Transmission: t-5, alum DS
Axle/Gears: 3.42 torsen posi, baer discs
>Every post here says: "set the correct pinion angle"....well, what is the right pinion angle? I've heard everything from zero to -3*..I'm driving aggressive street and track days, not straight line dragging. What are you guys running out there?
Old Feb 20, 2009 | 07:38 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: What is the Right Pinion Angle?
Each car reacts differently. For what you want to do with it, zero to -3* is about right. You need to see what works best for your car somewhere in that range.
Old Feb 22, 2009 | 08:08 AM
wdigitog's Avatar
Thanks....What angle do you have it set to? I assume you just go straight and fast with it!
Old Feb 22, 2009 | 12:08 PM
FueledSoul's Avatar
Car: 84 camaro, 88 trans am, 98 camaro
Engine: Modded , stock, LSX modded
Transmission: 700r4, 700r4, t-56
Axle/Gears: 327, 308, 373
How To Set Pinion Angle
Ask 10 Guys About Optimal Pinion Angle And A Lively Debate Will Ensue
http://www.carcraft.com/howto/91758/index.html
Old Feb 22, 2009 | 02:02 PM
ssean92's Avatar
Car: sold
Factory is set at -2
Old Feb 22, 2009 | 05:49 PM
wdigitog's Avatar
Thanks, Fueledsoul...great article....
jbates346
Oct 21, 2015 01:50 PM
gord327
Oct 3, 2015 01:25 PM
gord327
Sep 29, 2015 10:18 PM
mfp189
Sep 27, 2015 09:25 AM
dimented24x7
Sep 17, 2015 06:58 AM
