What would be the best...
Old Mar 1, 2009 | 12:47 AM
3rdGenIrocZ's Avatar
So my suspension is pretty bad when i hit little pumps. but on the high way its smooth. i swear i can feel every unleveld, any size bump in my car as im going through town.
I drive my moms focus right now because of winter and noticed a huge difference, i barely feel anything in the road with that thing other then bad rail road tracks lol.
Is this how all our 3rd gens are? or is there a suspension that would dampen the bumps
Old Mar 1, 2009 | 01:01 AM
Wrenchead84's Avatar
Car: 89 Camaro RS
Engine: 5.0 TBI
Axle/Gears: ???? want 4.10's
Re: What would be the best...
stock, struts and springs ride pretty good!!! and wouldn't cost too much either. unless you want a drop, thats a whole other world
Old Mar 1, 2009 | 01:47 AM
actually i just got my front end redone and i dont think they did any suspension. and i was thinking about dropping 1 1/2 inches. but dont know where. and how much would that stuff cost? like suspension parts? and how much for a drop?
Old Mar 1, 2009 | 12:14 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
If you want it to ride like the Focus, I doub't you'll want to drop it.
Old Mar 1, 2009 | 12:33 PM
i dont want it to be like the focus, im just asking if theres a way to make it ride better?
Old Mar 1, 2009 | 01:13 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Good shocks/stuts like Bilstein HD's or Koni's, but that is alot of $$$$. Then new springs and SFC's
Old Mar 2, 2009 | 10:18 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Your 3rd gen won't ride like your mom's Focus, dude. It's a new car with alot more development into the unibody so it'll make less nose and is probably more rigid. Plus, the Focus was designed to be nice riding comuter for people while the 3rd gen is a 'sports car'.
With that being said, the things to be done to improve ride would be
sound deadening- I've found that my car doesn't really ride as badly as it sounds. The noises produced from hitting bumps makes it you wince and you relate that to 'ride'
nice riding shocks with stock springs- probably standard Bilsteins, because the KONIs are vavled aggressivly for handling and I'd assume the Bilstein HDs are as well. Cheaper brands like Monroes, Gabriels are pretty much junk, but KYBs or Tokicos might work.
replace the worn bushings, etc- bad bushings will possibly allow metal on metal contact, and harshen ride as well as create extra noises
SFCs
Vetruck
May 1, 2013 09:01 PM
Tanker_
Jun 9, 2010 05:01 PM
dan_t
May 25, 2010 08:39 AM
