Preserving the Air dam?
Old Feb 19, 2009 | 06:56 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
I just replaced my old screwed air dam. I have already touch three times in 5miles. Did anyone tried to modify it, to glue some metal or any other tip?
I know that may be good springs with more correct ride height would be the best solution.
Old Feb 19, 2009 | 07:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Preserving the Air dam?
its most likely time for new springs and shocks/struts
adding metal will not help, if it hits the ground, its still going to break or bend something.
Old Feb 20, 2009 | 02:01 PM
loopingz's Avatar
My car is lowered, with Eibach springs. The damping is good too. But the car is close to the ground.
By metal plate I mean if on each touch the contact is on metal, I will let less plastic on the road and the metal is dead I can change it.
Anyone want to trade for upper springs and dampers?
Old Feb 20, 2009 | 03:03 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
You're probably either too low or have ishy shocks up front if you hit it three times on 5 miles of normal road.
I drag the hell out of my air-dam all the time going in and out of places such as drive ways and parking lots and some speed bumps. Been doing it for 3 years. It's not going to wear out fast.
Old Feb 20, 2009 | 04:30 PM
racing geek's Avatar
Car: 1987 IROC-Z
Engine: 383 with Edelbrock ProFlow EFI
Transmission: TH350
Axle/Gears: 12 bolt 3.73 Eaton posi
Originally Posted by 91_5.7_TPI
I drag the hell out of my air-dam all the time going in and out of places such as drive ways and parking lots and some speed bumps. It's not going to wear out fast.
It has been the same thing for me too. It will last a while unless you are literally dragging it. A tap here and there won't do much damage to it.
If you're really concerned... check out the wear strips and wear plates in this link.
http://www.pegasusautoracing.com/gro...oupID=HARDWEAR
Mike
Old Feb 23, 2009 | 08:22 AM
loopingz's Avatar
Thanks for the link, it could be a good solution. But 20$ for 40inches, it is the price of a new air dam ( without shipping). I will see.
Old Feb 23, 2009 | 08:30 AM
Stephen's Avatar
Car: 87 GTA
The air dam will last for YEARS with the occasional driveway scrape. Just go slow into ramped driveways & minimize the amount of scrape they get.
On both my lowered 90 RS & 92 RS, they both did that into steep-ish driveways & road dips....Neither one broke or fell off. Both were fine for years.
Old Feb 23, 2009 | 12:25 PM
Darkshot's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: WC T5
Axle/Gears: 3.42 Posi
Yeah, I beat the crap out of my air dam. Before I had shocks/springs, it would drag on a hard stop from highway speeds. Stock height springs and good shocks have eliminated most dragging. It will last awhile.
Old Feb 23, 2009 | 01:18 PM
loopingz's Avatar
Yes I hesitate to go back to stock height.
Old Feb 23, 2009 | 03:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
I just made one out of some polished alluminum (like 1/8 thick) i had laying around, do you think the alluminum will be too stiff and not give enough?
Old Feb 23, 2009 | 03:37 PM
loopingz's Avatar
I think it will bend, definitely...
Old Feb 23, 2009 | 03:39 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
If I had one made from aluminum, I'd bend it up in about two days. I scrape just about anywhere I park at home except for one spot, and that's mom's.
Old Feb 23, 2009 | 03:47 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Hmm thats what i was thinking. Well i could keep it on there and see how much it bends, if nothing else i'll have to buy one. Or for shows i could swap on my alluminum one and look purdy lol.
Old Feb 23, 2009 | 04:14 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
i dont run an air dam. and i seem to have no problem with overheating on the highway.
Old Feb 23, 2009 | 04:29 PM
Stephen's Avatar
Car: 87 GTA
You must only drive on the interstate/highway. And you have a Camaro. Firebirds have no other inlet for air over the rad, other than the air dam.
Old Feb 23, 2009 | 07:35 PM
actually i drive in the city aswell. i guess what helps me is here in the bay area it isnt really that hot. actually its usually pretty chilly year round
Old Mar 2, 2009 | 11:00 AM
87TransAm_GTA's Avatar
I have a 87 gta that I got recently and it doesn't have an airdam. It will get hot going down the highway no matter what the temperature is outside. It's fine in town and idling and I have been through the coolant system. Mine blows water for a minute or two when you first start it, but that is condensation in the pipes and it completely dries up after the exhaust heats up so it's not a head gasket I'm pretty sure. I thought about making an airdam out of one I have on a little s10 pickup, but I haven't looked to see how much one for the gta will cost yet.
Old Mar 2, 2009 | 11:51 AM
loopingz's Avatar
I had mine for 20$ plus shipping brand new. It was way better than the old one which was in bad in shape. With nothin my engine would be already dead.
Old Mar 2, 2009 | 11:53 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
I'd grab an air dam from a junk yard. That'd probably fix the problem with heating on the highway.
Old Mar 2, 2009 | 12:37 PM
Someone said the fans cut off around 40 mph, is that true?
Old Mar 2, 2009 | 12:41 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Never heard of that. I'll test it next time I'm out and actually manage to get the fans to cut on lol.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
tommy z-28
Oct 6, 2015 10:58 PM
edoff13
Sep 11, 2015 03:55 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
