Vibration at 70
Old Mar 1, 2009 | 07:25 PM
MBcamaro1990's Avatar
Car: 1990 Camaro
Engine: 305 TBI
Axle/Gears: G92 3.42
Vibration at 70
Once I get to exactly 70mph in my Camaro, the thing starts shaking real bad. The one time I went 100 my shifter was shaking so bad I could barley grab it. The car still tracks straight though. Is this just an alignment issue or do most third gens shake at higher speeds.
Old Mar 1, 2009 | 07:37 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Vibration at 70
my car is smooth at 120mph. they are not suppose to shake. vibrations means something is unbalanced. perhaps driveshaft. wheels. etc. get them checked.
Old Mar 1, 2009 | 08:49 PM
loopingz's Avatar
Car: 89 Camaro IROC-Z
Engine: 350 TPI crate
Transmission: 700 R4
Axle/Gears: 9 Bolts Borg Warner 2.77
Re: Vibration at 70
Same here, I would gat the wheels balanced first, then a aluminum equilibrated drive shaft.
Old Mar 1, 2009 | 09:00 PM
Jeff91RS's Avatar
Car: 91 RS
Engine: 350 TBI
Transmission: World Class T-5
Axle/Gears: 3.27 9-Bolt LSD
Re: Vibration at 70
I was getting some weird vibrations last summer, it was because a cap fell off of my rear u-joint.
and loopingz in your profile on the side it says you have a "9 bolts borg wagner" its a 9 bolt borg warner. just wanted to let ya know
Old Mar 1, 2009 | 09:06 PM
loopingz's Avatar
Re: Vibration at 70
Thanks for your input, now I will remember. It is gorrected!
Old Mar 2, 2009 | 10:14 AM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Vibration at 70
Allignment has nothing to do with the vibration. The problem is most likely in the wheels/tires being out of balance. I don't know how so many people get these issues confused.
Old Mar 2, 2009 | 03:09 PM
redcatch32's Avatar
Car: 1988 Camaro Coupe
Engine: 420
Transmission: TH 400
Axle/Gears: 2.77
Re: Vibration at 70
Never discount the Transmission mount. I have a 400 with a Turbo 400. We chased a vibration that pulsed at 65 and was speed related. Changed every thing. Last week had a custom drive shaft built that required a bigger loop. Still had the vibration. Took the transmission mount out and put a stock mount in and it is as smooth as any SCCA road racing car can be. Go figure. I believe that it was just so tight that it was transmitting all vibrations into the body.
Old Mar 2, 2009 | 09:34 PM
Car: 1990 Camaro
Engine: 305 TBI
Re: Vibration at 70
Well that's out, I already had all my caps fall off at once. That was a whole lot of vibration! I guess I will try to balance the wheels again.
Old Mar 2, 2009 | 09:51 PM
bbpping's Avatar
Re: Vibration at 70
For me it was the torque arm mount that was shreded to pieces, i replaced that with a poly one and it was running perfect after that
69GTOby
Apr 18, 2016 02:34 PM
sac92transam
Oct 7, 2015 02:31 PM
roysatikas
Sep 22, 2015 08:15 PM
BWilcox
Sep 20, 2015 12:19 PM
InfinityShade
Sep 18, 2015 08:32 PM
