All spherical rod ends on street car?
Old Mar 13, 2009 | 03:32 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
I'm planning out my rear suspension rebuild, and I'm leaning towards using spherical rod ended parts for everything - LCAs, track bar, and torque arm. Has anyone done this on a street driven car? I'm wondering how much it will increase road vibration being transmitted to the car body.
Old Mar 13, 2009 | 03:52 PM
Stephen's Avatar
Car: 87 GTA
Re: All spherical rod ends on street car?
I have a rod-ended UMI Performance Panhard Bar, ans am on 17" tires, so shorter sidewalls than your 16" tires.
I noticed NO increased vibration or noise. Double rod-ended rear LCAs are next on my list.
Old Mar 13, 2009 | 08:43 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
You won't have much affect at first, but you'll have to replace the rod ends, and that can get expensive.
Old Mar 13, 2009 | 09:21 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
I didn't notice much but then again I did sportlines at the same time so the car was bumpy as hell until I put new struts/shocks on it. Noise didn't get bad until this last year. The LCAs are still good but the panhard bar rattles a bit because the rod ends are loose. That's about 4 years of street driving. A bit over 100k.
Old Mar 13, 2009 | 11:11 PM
Guest
Guest
Posts: n/a
Good rodends that will hold up to daily use for 3 years "without" problems will cost you close to $100 each.
I mean zero problem rodeneds, not ones that have a little slop.
Old Mar 14, 2009 | 12:47 PM
91_5.7_TPI's Avatar
Car: 1991 RS Camaro
That's why I think I'm going to replace my worn rod ends with the rubber ends I have on the body ends of my LCAs.
I can swing ~$100 for all alot easier than ~$300+.
1992rs/ss
Jan 31, 2025 05:10 PM
Terrell351
Jun 13, 2021 01:13 PM
Reborn756
Sep 4, 2015 03:42 AM
gwade12
Aug 8, 2015 08:17 AM
z28addict8490
Aug 7, 2015 08:48 PM
