manual steering box
Old Mar 22, 2009 | 12:15 PM
white85transam's Avatar
Car: 85 trans am
Engine: 383 stroker
Transmission: 5 speed
Axle/Gears: 9 bolt rear 3:70
manual steering box
i just got a manual box from an s15 yesterday and i was wondering how do you add fluid to it. i ask because when i turn the pitman arm i can feel the gears in it so i figure it may need new fluid. or is that normal? can anyone tell me how to do this and what and how much it takes?
i wanted to do this before i install it and have to take it out if its bad. also does anyone have any tricks for getting the pitman arms off i still have the s15 one on the new pump and mine is still in my car.
Old Mar 22, 2009 | 12:42 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Re: manual steering box
A manual steering box is full of grease not oil.
To get the pitman arm off, you need a pitman arm puller.
Old Mar 22, 2009 | 12:49 PM
Car: 85 trans am
Engine: 383 stroker
ok is there a way to add grease? or is it a sealed unit and yourun till it stops working?
i guess what i meant about the pitman arm is how to get the nut loose once removed from the car.
Old Mar 22, 2009 | 02:25 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Top top cover can be removed to fill with grease.
The pitman arm nut is usually removed with an impact gun. You could always try putting it in a vise to remove the nut if it's not in a vehicle.
Old Mar 22, 2009 | 03:36 PM
Car: 85 trans am
Engine: 383 stroker
is there any particular type of grease? i have some of the red hi temp bearing grease will that work???
Old Apr 5, 2009 | 11:34 AM
Car: 85 trans am
Engine: 383 stroker
ok i added grease and when i pulled the cover off i there was some pressure built up that was released when i seperated the cover from the box. is this normal? also i noticed that if you tried to turn the shaft the steering colum connects to it was hard to turn and now it turns pretty easilysince i pulled the cover. is this box still good?
i also have another one that turns easily that i pulled from another truck from the yard and i havent taken the cover off of. should i use this one instead?
1992 Trans Am
May 10, 2023 07:19 PM
Amillionoh7
May 24, 2020 08:01 AM
MyRedCamaro
Dec 29, 2015 05:16 AM
backtothe80s
Sep 5, 2015 12:39 AM
zayne0
Aug 24, 2015 07:22 PM
