Need another inch or so
Old Mar 22, 2009 | 02:01 PM
Samdweezel05's Avatar
Some of you may know that I lowered my GTA. I am still not happy with the way it sits. Front end still needs to come down more. Right now the car is level but the fender gap in the front is just too much. What can I do for this? I don't want to do spindles. I should also mention that the front springs are still not correct in the pocket in the A-arm. They are turned about 90 degrees counter clockwise. I know it will drop a little when I turn them but I don't think it will give me what I want. How else can I get it where I want it? 285-35/19 in the rear and 245-40/18 in the front. It is exactly 27.75" from the ground to the top of the fender arch on all 4 corners.
Phil
Old Mar 22, 2009 | 03:58 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Need another inch or so
what springs are you using?
really the only way you will get lower than that with your current springs is to cut them, which people have mixed opinions about.
Old Mar 22, 2009 | 04:44 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
re seat them, see if that helps.
when the spring is seated, the bottom coil is touching the a arm, so it is effectively not doing anything. if the spring is not seated, the bottom coil not only lifts the car, but affects the rate.
if you arent happy after indexing the spring correctly, then cut half a coil off.
the rear looks great though
Old Mar 22, 2009 | 05:35 PM
howy03's Avatar
Car: 1985 Pontiac Trans Am
Index the front correctly drive it a bit and see how it looks.The front is just a tad off.The car sits nice. What springs u use?
Old Mar 22, 2009 | 05:53 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
also, the driveway is sloped, so that could have an effect
Old Mar 23, 2009 | 11:22 AM
Springs are Hotchkis. I took the pic on the driveway because it is hard to get a good pic inside the garage with the other car in the way. I will set them right and then see what I have.
Hey howy03. I bought this car down by you last May.
Phil
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
gord327
Sep 29, 2015 10:18 PM
