front struts
Old Mar 27, 2009 | 11:26 AM
rvega022's Avatar
front struts
I am in the process of rebuilding the front end of my 1986 IROC-Z. I just removed the struts and when I compress them, one will rebound slowly and the other won’t; could this be a sign of a bad strut because it doesn't rebound?
If it is, should both struts be replaced?
Thanks in advanced, you guy always have valuable information to share!
Old Mar 27, 2009 | 11:55 AM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
Re: front struts
sorry, it is time to replace them.
Old Mar 27, 2009 | 04:33 PM
WASyL's Avatar
Car: 1988 Pontiac Firebird
Engine: 305 LT1 intake&heads
Transmission: TH700r4
Axle/Gears: 3.73 10bolt GM
Re: front struts
yes, and remember struts (and shocks) needs to be replaced in pairs, never ever replace only one.
best regards
Old Mar 27, 2009 | 10:31 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Re: front struts
best regards
How about only doing shocks? I plan on doing the front struts when i "hopefully" upgrade my brakes. MY struts feel fine too.
Old Mar 27, 2009 | 10:38 PM
Duratys's Avatar
Car: 91GTA 89TTA
Engine: 305 3.8 Turbo
Transmission: MK6 2004r
Axle/Gears: G80 3.42s 3.27s
Re: front struts
Id say if the shocks are done the struts wont be far behind....might as well do everything.
Old Mar 28, 2009 | 12:45 AM
a1990camarors's Avatar
Car: 1990 rs 1992 z28 1995 jeep
Engine: no engine, 383stroker, inline 6 4.0
Transmission: none, t5, auto
Re: front struts
you dont exactly have to do all 4 corners at once but defiently switch the front and rears as a pair never replace just one front or just one rear.
Old Apr 3, 2009 | 10:23 AM
rvega022's Avatar
Re: front struts
I just finished replacing both front strutes and at the same time rebuilt the font end including replacing the power steering gear box. WOW what a difference you can feel driving the car now.
I'll be rebuilding the rear bushings and struts soon.
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
NORTz89
May 20, 2020 03:51 PM
Polo Z03
Wheels and Tires
49
Jul 21, 2017 12:31 AM
redmaroz
Apr 25, 2017 07:14 AM
