Manual Steering Gear
Old Mar 29, 2009 | 12:17 PM
1985hotrod's Avatar
Hey guys anyone used a manual steering gear from a s-10? Going though part books I found one that bolts right up to my 85 firebird. The question I have is do I need any different pitman arm. It bolts up ok I just don't know if the geometry is corrrect. Anyone done this before?
Old Mar 29, 2009 | 12:39 PM
dennisbernal91z's Avatar
Car: Building LS3, T56 Z28
Engine: LS3
Axle/Gears: Moser/ 4.11
Re: Manual Steering Gear
many people have done this swap before. I have a manual box that I am trying to sell. It is a borgeuson box made for third gens, it comes with a pitman arm made just for it. It was expensive when I bought it but i will let it go for a lot less. Lemme know if you are interested in it. PM me. Later.
Old Mar 29, 2009 | 02:56 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
84+ S10 manual steering boxes are a direct bolt in. The pitman arm is a slightly different length so you should use the third gen pitman arm to keep the same steering geometry.
Old Mar 29, 2009 | 03:50 PM
1985hotrod's Avatar
Thanks. I thought that was the case. Just wanted to be sure. Nice burnout. What is your e.t.?
Old Mar 29, 2009 | 03:53 PM
1985hotrod's Avatar
ah i see 9.36 @ 144 Thats Flyn
1992 Trans Am
May 10, 2023 07:19 PM
Vintageracer
Jan 10, 2020 05:33 PM
backtothe80s
Sep 5, 2015 12:39 AM
mizz0313
Aug 12, 2015 06:45 AM
