Tell me if this is correct
I searched around and got a couple different opinions on this.
I have 06 OEM corvette c6 rims that will be going on my 3rdgen which has a 3rdgen rear.
I was thinking I need 2 inch spacers for the front and 2.25 for the rear. Does this sound right. I think the rear wheels are 19x10 or 19x10.5
Let me know thanks!
Let me know thanks!
Car: 1991 RS Camaro
Engine: L03 (want LS1)
Transmission: 700R-4 (and T56)
Axle/Gears: 4th Gen 3.23 posi
Re: Tell me if this is correct
I think that would be right. Although, the 2.25s might space the rears out funny.
There is a thread at the top of the forum that'll show you the equation to find what you need just to be safe.
Car: 1991 RS Camaro
Then there's this as well. Seems like your right.
Car: 91 Z28
Transmission: t-56
Axle/Gears: 3.73 4th gen 10 bolt
It takes a 1.25 to fit the rears on a 4th gen, and those rears are 3" wider than the third gens. So you might need a bigger spacer in the back. You should be fine on the front though.
sjorgens
Oct 1, 2015 07:54 PM
