GM Aluminum Wheel Torque Setting
Old Apr 7, 2009 | 03:36 PM
1985blktransam's Avatar
Car: 1985 Firebird Trans Am
Engine: 5.0 Liter Engine
Axle/Gears: 3.08
Hi:
Anyone know what the correct Factory Torque Setting is for Firebird Trans Am Aluminum Slotted wheels ???
Apparently the tire shop and mechanic have 2 different views on the subject.
Rob
Old Apr 7, 2009 | 04:14 PM
84redta's Avatar
Car: 80 SE/TTA;88 T/A GTA;86 T/A
Engine: 4.9L Turbo; LT1; empty
Transmission: TH350; T56; empty
Axle/Gears: 3:23 disk; 4:10 disk ; 3.42 disk
Re: GM Aluminum Wheel Torque Setting
Torque is 80, not 100 (just an assumption of what the two were arguing). 100 should not hurt it though, the 80 torque stick that they will use will put it very near 100. You can see this when you go to use a torque stick after torque sticking all 5 lugs.
Jon
Old Apr 7, 2009 | 05:57 PM
Axle/Gears: 3.08
Great. Thanks for the info
Rob
Old Apr 8, 2009 | 09:39 AM
Shagwell's Avatar
Car: projects.......
with stock wheels I torque them till the impact goes bap-bap-bap.
My billets I torque to 85ftlbs.
Old Apr 8, 2009 | 10:50 AM
Guest
Guest
Posts: n/a
I second the 85 lbs. Any more just starts harming the wheel stud threads and lugnuts. I do 85 on aluminum or steel wheels.
Vintageracer
Jan 10, 2020 05:33 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
Navy8125
Aug 22, 2015 07:13 PM
kah992
Aug 19, 2015 02:55 PM
