Axle Code help / Bent Rear axle
Old Apr 10, 2009 | 12:24 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
Transmission: HD 700r4 B&M Stage2 SK
ive got a 1990 iroc with 5.7 TPI, its got rear discs,
ive apparently really bent the right rear axle shaft and my shops are having trouble finding a new one, i may have found one but i need to know the spline and ring gear sizes/numbers to confirm it on ebay
ive been under the car and am not able to find the code and could really use some help in this.
any input im sure would help
thnx Erick
Old Apr 10, 2009 | 12:56 PM
akmusclecar's Avatar
Car: 1988 Pontiac Firebird
Engine: 5.0 TBI
Transmission: W/C T5
Axle/Gears: 3.08 Posi
Re: Axle Code help / Bent Rear axle
If it is a 10 bolt, you should have the 28 spline axles.
Old Apr 10, 2009 | 01:00 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
great, now i just need to figure out the ring gear ... lol
and does anyone know how long the shaft should be the on eim lookin at is 30 5/16 in"
Old Apr 10, 2009 | 01:16 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Here's the FAQ (I assume you have a 10-bolt):
https://www.thirdgen.org/forums/tran...-10-bolts.html
JamesC
Old Apr 10, 2009 | 01:42 PM
vendetta's Avatar
Car: 1990 Iroc-Z28
Engine: 350HSR
great! thanks alot guys, i was able to figure it out thnx
hectre13
Dec 11, 2023 08:14 AM
customblackbird
Aug 15, 2021 10:16 PM
Cameeeero
Sep 18, 2015 04:00 PM
E Rod
Aug 28, 2015 05:17 AM
