Front Coil Spring Noise
Old Apr 11, 2009 | 09:06 PM
kaupca's Avatar
Car: 92 Camaro RS
I have 1992 Camaro RS that when I hit a bump it sounds like the front right spring reseats itself afterwards. The front coils were replaced aout 3 years ago with stock Z28 springs, Also installed new isolators. About a year before that put in new ball joints, A arm bushings, sway bar bushings, sway bar end links, struts, strut upper mounts, tie rod ends and idler arm. Checked the car today and found nothing lose in the ball joint, wheel bearings or sway bar. Problem seems to be geting worse. What else should I look for?
Old Apr 12, 2009 | 05:38 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Re: Front Coil Spring Noise
It would seem very unlikely to me that your spring is reseating itself. There is an enormous amount of pressure on the springs when the A arm is bolted up, it shouldnt move. The only thing i could think of regarding that would be if your spring is bent somehow at the bottom, which might cause it to move a little, but even that seems highly unlikely. Are you sure your not getting a pop from your strut? And what do you mean by worse?
I recently installed new shocks struts and springs and sometimes my right front pops when going over a speed bump. I Havent had time with school to get under there and see if everything is okay but it only happens every once and a while. If i can get out there sometime this week ill see if i can locate a problem seems like were havign the same issue. But i doubt it could be the spring.
customblackbird
Aug 15, 2021 10:16 PM
B_Dubya
Aug 26, 2015 05:09 PM
TheExaminer
Aug 25, 2015 07:34 PM
TA8487
Aug 11, 2015 09:02 PM
