Power rack and pinion
Old Apr 14, 2009 | 06:03 PM
SomeGuy25thZ's Avatar
Car: 1992 z28
Engine: 383 LT1 in the works
Transmission: T-56 in the works
Axle/Gears: 3.73 in the works
Anyone know where I can get a power rack and pinion setup for a 1992 z to work with Spohns LTX swap K-member?
I already searched and there is just more talk than actual info. Some custom fab setups using mustang steering parts but I can just as easily just go to a shop and have them do that. Anything for my setup?
Old Apr 14, 2009 | 06:05 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Power rack and pinion
you have to obviously make mounting tabs and weld them to the k-member.
the 4th gen R+P unit is commonly used. One of these days i may do it.
Or, buy Racecrafts k-member for the lsx swap with the rack mounts installed and ready to go. they even sell the custom spindles so you can retain your stock steering radius. $$$$$
Old Apr 14, 2009 | 08:41 PM
Car: 1992 z28
well my whole purpose for doing this is to get rid of the steering gear so I have clearance for the 1994-1997 F-body procharger kit for the LT1 (it mounts low on the drive side). I am not even sure this is going to make enough room but I guess i am going to have to go to the local race shop and see what they can do for me.
Old Oct 29, 2009 | 05:49 PM
f body king's Avatar
Car: 92 camaro
Engine: working on 427 twin turbo
Transmission: richmond 6 speed
Axle/Gears: 9in ford with 3.25 diff. gear
Don't know where you can get a power rack and pinion setup for the ltx swap k-member, but in about 3-6 months I am making a power rack and pinion set up for 3 gen camaro's. The set up will be geared toward road racing applications.
Old Oct 29, 2009 | 07:26 PM
Iroc-Z28Man's Avatar
Car: 86 Iroc-Z28 Camaro/84 BMW M Power
Engine: 350TPI/ S50
Transmission: t-5 five speed/ 5 speed
Axle/Gears: 3.42 posi/ 3.73LSD
Try Flaming River. I know they make stuff that works with BMR K-members.
Old Dec 3, 2009 | 05:17 PM
R S's Avatar
R S
will it use stock 4th gen rack?
Terrell351
Jun 13, 2021 01:13 PM
lt1z350
Sep 29, 2015 01:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
89fast5oh
Aug 24, 2015 08:14 AM
overdriv
Aug 20, 2015 03:52 PM
