Clearance ?
Old Apr 20, 2009 | 09:10 PM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Clearance ?
I have a Hooker long tubes with a Mufflex system. And currently my ground clearance is I can roll a pop can under with out hitting the Mufflex and thats about it. This is with a 150,000 mile plus on the current stock spring & strut ride hieght. I'm replacing the struts and springs with Lakewood Struts And Morrosso Trick Springs. I have the option of using uncut trick springs or 1" cut trick springs.
My question is; due to the old spring strut sagging if I go with the new 1" cut springs would the ride stay the same as the old or would it get better/worse? Or should I use the new uncut springs which will probley raise the front more than I would like for looks.
I also have LCA relocation brackets that I can use too.
Old Apr 21, 2009 | 08:42 PM
Car: 1988 IROC-Z28
Re: Clearance ?
So no one has experienced this issue, or has any suggestions, ideas, etc. ?
Old Apr 21, 2009 | 09:49 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Re: Clearance ?
I remember replacing my 1982 50k mile front springs with some uncut moroso trick drag springs that lifted my front end up about 3/4".
Old Apr 21, 2009 | 09:54 PM
Car: 1988 IROC-Z28
Re: Clearance ?
Wow is that normal, as I would have thought those springs or simular would have at the most put the ride height at factory.
Old Apr 21, 2009 | 10:35 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Re: Clearance ?
It might be different if you get the SBC springs. I got the BBC springs since the front end of my car is in the 1900lb area that the BBC springs are rated for.
z 28 jari
Sep 14, 2021 10:03 PM
91 SrS
Oct 7, 2015 04:32 PM
86z89iroc
Oct 5, 2015 01:04 PM
Night rider327
Sep 16, 2015 02:20 AM
